Need pinout for TLO62CP
  • Need pinout for TLO62CP
    Working on ML schematic & can't find the data sheet on this part also could use one for a 40 pin 68HC705C8P I can't find the 40 pin case on the Motorola web sight.
    Re: Need pinout for TLO62CP
    TL062
    1 = out (1)
    2 = - (1)
    3 = + (1)
    4 = VCC-
    5 = in + (2)
    6 = in - (2)
    7 = out (2)
    8 = VCC+
    Sorry don't have the other chip.
      PDF link
      PDF link
      Click Here
        Wasn't easy to find. Page 192 has the pin out for the 40pin dip package.
        JJ
        http://e-www.motorola.com/files/microcontrollers/doc/data_sheet/MC68HC705C8A.pdf
        Click Here
          Re: Need pinout for 68HC705C8 40 PIN
          I think this is what you need. Hope it helps.
          Russ
            Thanks, the Sovereign schematic is coming along
            Thanks, that is what I was looking for. The Sovereign schematic is coming along, I have from the preamp through the second amp, the demodulators and the filter stages drawn. As soon as I get it re-drawn with the eagle software I will start posting it.
              Re: Thanks, the Sovereign schematic is coming along
              David
              I have the Motorola Applications guide for that Micro,,, I think it is probably a bit more extensive than the Data book. I haven't written any code in years, but if I can be of any help please don't hesitate to ask.
              Russ
