The height of the RX Gain setting in the 3F multifrequency will depend on the mineralization of the terrain.
1-2 bar Fe3O4- low mineralization setting RxGain up to 10-14..OK
4-Bar Fe3O4-medium strong mineralization setting RxGain to 7-8.OK
7 bar Fe3O4 - extremely strong Mineralization- Gain adjustment up to 3-5 OK ..
I use the sensitivity of DS for a good depth of 85-93 ...
Ground filters 7.5hz and 10hz Band /High ...will be the most versatile ....
for ..Deep........ recovery delay is ideal for me at 60-75 .. independent of the type of coil used ...
If you want to greatly improve the separation, put the bottle cap on OFF.
