Good evening to all the members of this Forum, I need your help, my question is, a few years ago I made two metal detectors treasure eldorado, but after numerous tests, and having failed to have a working ground balance, I put them on part, then I made idx pro by buying the pcb from silverdog, the same worked the first time. These days reading on the forums I managed to make the two eldorado work. My question to you Gurus, does the IDX need a tune-up with the resonance between TX and RX as in the eldorado, or not. In eldorado to be able to cut ferrite / GB it is essential to find the right resonance. Thanks for your kind reply.
Tesoro Eldorado and Idx pro resonance.
https://www.geotech1.com/forums/show...ldorado-Tesoro
- What is the advantage of Parkinson's disease vs Alzheimer's disease?
- It is better to spill a few drops of brandy from the glass when you carry the glass to your mouth than to forget where you hid the opened bottle.
pleasure
Originally posted by dgm View PostGood evening to all the members of this Forum, I need your help, my question is, a few years ago I made two metal detectors treasure eldorado, but after numerous tests, and having failed to have a working ground balance, I put them on part, then I made idx pro by buying the pcb from silverdog, the same worked the first time. These days reading on the forums I managed to make the two eldorado work. My question to you Gurus, does the IDX need a tune-up with the resonance between TX and RX as in the eldorado, or not. In eldorado to be able to cut ferrite / GB it is essential to find the right resonance. Thanks for your kind reply.
Once achieved there's nothing to be gained by changing except in air tests
I don't have the Eldorado but IDX vs Bandido the Bandido is a clear winner "IN THE FIELD" better discrimination and true no motion mode.
The IDX preforms better on the bench. And will probably depend on your ground conditions.
I used both for several years. With real in the field settings, both with 10" coil the Bandido hits a target on my lawn that the IDX will not without lower the discrimination to a point where you would be digging iron all day
