SS points, what is the diameters of the head and shaft?
Metal detector for finding archery arrows
Originally posted by Mothough View Post...Using a neodymium magnet a M6 50mm long A2 bolt will stick to the magnet whereas the arrowheads show only the slightest interaction with the magnet...
Obviously pretty tough target for detector.
...whether combing the soil surface with a rake would help...
Originally posted by Mothough View PostShaft is 4.2 or 4.4mm in diameter and depending on manufacturer 35 or 45mm long
Head is 5.5 or 6.0mm in diameter and typcially 15mm long
Question. If I made a target with aluminum foil same area and TC as head would they both detect at similar distances?Attached Files
Originally posted by Mothough View PostThe arrows have stainless steel heads which are 4 - 5mm (150 - 200 thou) in diameter, 3 - 5cm (1 - 2 inches) long and have a weight of 5 - 8 grams (0.2 - 0.3 ounces)
Originally posted by Carl-NC View PostThis is similar to hunting gold nuggets, so I would suggest a VLF gold nugget detector. Something 15kHz or above. I doubt you need a high-end model (~$700) but the problem is there are not many low-priced gold detectors out there. The Fisher Gold Bug (digital) comes to mind but it is still $500. I would look for something used and older. The White's Goldmaster II or Goldmaster VSAT would be good choices. Avoid the really old White's Goldmasters in the big blue boxes, they will be useless. Another good option but hard to find is the White's GMZ, which was a stripped down GMT. Finally, an old Fisher Gold Bug would work well... this is the 1990's version that looks like the newer Gold Bug II, not the newer digital Gold Bug. Confusing, eh?
Thanks again for all the effort and details you guys are putting into this. Looks like I have to save up for one of the suggested ones.
Looking at the parts list of a Surf PI, they are all jellybean parts and I might be able to source them from my electronics bin and build one up on breadboard. Do you see any realistic chance that it would detect such an arrow head?
Are there any similar VLF like designs and would it be benificial to further up their operating frequency to make them more sensible to stainless while sacrificing detection depth?
Originally posted by Mothough View PostThanks again for all the effort and details you guys are putting into this. Looks like I have to save up for one of the suggested ones.
You might want to visit a detector dealer and take an arrowhead with you. See what will & what won't detect it. If you are lucky, they may still have a Surf PI in stock (White's just went out of business). Once you know what will work, you can then figure out what you might be able to build if you want to go that route.
Originally posted by Carl-NC View PostYou might want to visit a detector dealer and take an arrowhead with you. See what will & what won't detect it. If you are lucky, they may still have a Surf PI in stock (White's just went out of business). Once you know what will work, you can then figure out what you might be able to build if you want to go that route.
Only way to really know is to try detectors on the arrow shaft you have.
Maybe there is someone over there in the EU you can send a shaft to for testing.
A good and well established place is the dcg detector center in Rodenburg. Have a look at their website.
www.detectorcenter.de
Google DCG Detector Center if above does not work.
Originally posted by green View PostDon't know what your ground is like.
Originally posted by green View PostWith my ground I wouldn't purchase or build a detector that couldn't GB.
For now I'll try to build up the Surf PI design because I can do that without spending any money. Then I'll have at least a reference, since I do not own any metal detector equipment. In the following weeks I'm quite busy, so I'll probably not get to it immediatly, however I'll keep you posted. Furthermore I found a few design variations mostly differing in component values. I also found a design where the ICL7660 voltage converter seems to be synchronized and a gain potentiometer was added. Does anyone know which one is the most recent and most promissing design?
