Hello, detectorists. Did anybody assembled Delta pulse PI detector? i would like to know somethink about adjusting and tech data about this detector, thanks for all
The construction of Delta-Pulse doesn't put any probléme.
Concerning R39 and R40 to respect values of the diagram. The XR71 is different on this point and the T8 transistor is a PNP.
Concerning R1 and PR1 authorizes the adjustment of the frequency of the pulse. Delta - Pulse works to 100Hz and the XR71 over of 300Hz. my delta-pulse operates to 400Hz.
I replaced R1 by a 120k.
The frequency is given by the constant of time (R1+PR1)*C1.
If you don't have of oscillo to respect R1 to 680K and replaced PR1 by a strap.
The frequency of beating is not critical if one doesn't pass certain value.
Attention on the printed circuit it is necessary to add a strap between the paw 2 and 6 of the IC8.
nice job, and your PCB is perfect, i used older version of PCB and there was an error with vd12 and vd 13, this is why sensivity was so low, after i fixed it sensitivity is growed up and now i need to shield everythnk because it feels everythink around
