White's metal detector
  • White's metal detector
    Hi to all with white's detectors. We are looking for low end or older whites detectors.We want to test some mods on or burn them up : :b :b :b It is the only way to learn the insides of the magic box.
    If you have any you want to sell let us know at [email protected]
    Re: White's metal detector
    I own five Beachcomber 4, two Beachcomber 2, one Coingetter 2 and one Minimaster.
    The BC4, the BC2 and the CG 2 have all the same very simple circuit: 5 transistors, no IC.
    You can match a 4B coil or a 2D (doublet) coil to all these machines. I prefer the 2D coil because it is less sensitive to mineralised ground. You can fit the Beachcomber as well as the Minimaster with coils of different sizes:
    6", 8", 10". I prefer the standard 8" 2D coil, because it is the most polyvalent coil: deepseeking and hot on tiniest metal parts.
    André
