REG1117A.lib proteus 6 prof
  • REG1117A.lib proteus 6 prof
    hello
    i working here with proteus 6.0 prof.
    who can help me with the library of te LDO regulator REG1117A.
    i redesign the pcb of gary's PI detector.
    i can not finded for this component.
    rgds kurt.
    Re: REG1117A.lib proteus 6 prof
    If I remember correctly on one of Gary's newest update pages he mentions some subsitute IC's that can be used in place of the REG1117A. He mentions that they weren't as good as the REG1117A but that they would work. I also believe he mentioned that you can order parts from him. Hope this helps.
    HH
    Beachcomber
      You could use a LM317 as a sub for the Program. If Possible Change the input to output voltage. Basically the REG1117A is very Simular, but has a Much lower Foreward voltage drop.
        hi
        thanks everyone for the reply.
        kurt
