I have worked in Pulse induction project, and I
use a FET FQP3P50, FET P-channel, because i'm using microcontroller and
P-channel is easer to interface with microcontroller.
The circuit is working well, but I need more distance to get metal, more
sensibility, I got 30cm steel that have in the standard of metal detector. I tested different delay, pulse width, frequency and I don't have success.
If I increase the gain of the op-amp the output signal is unstable and it isn't good read with the AD from microcontroller.
I use a coil with 22 turn and the size is 9.8" x 19.6" (25 cm x 50 cm), but
I tried many other number of coil turn without good results.
The breakdown voltage of the PFET is 500V.
I tried to use post-gain filtering but I think that the my circuit is on
the maximum gain and after that there is a lot of noisy.
I use the 70uS on the pulse on the coil and 20uS how delay and 100uS window
of the sample. I tried to change all this parameter without good results.
I'll try the coil concentric, I think I'll get more sensitivity.
How many turn does RX coil ? How can I make this kind of coil ?
If you had some tips, or some good idea, please help me.
Best Regads,
Gilmar
Best Regads,
Gilmar
