Coin Check
  • Coin Check
    I would like to know what is principle of Coin Check feature in Shadow X2. I want to add Coin Check to my Silver Sabre. Maybe someone who reads this will know more and post it here.
    Re: Coin Check
    what SS you have - it is DIY?
    Pepso, what I think about... here was a comprehensive schematic of Tesoro (I hope you saw it), take a look on "notch" part. I suspect it was released of the way.
      Re: Coin Check
      Actually guys, it's just a preset potentiometer which is switched in instead of the existing DISC pot.
      Nothing so complicated as a notch ;-)
        Re: Coin Check
        No Pepso a ja som si myslel,ze pouzivas Tracker PI-2 :-)
          Re: Coin Check
          Pripravujem Urob si sam repliku SilverSabre!
            Re: Coin Check
            Si dobry!Ja som vyriesil PICsoft do Treasure Huntera od Marka Stuarta,funguje to!Nehodil by si to na svoju stranku?
              Re: Coin Check
              OK, posli vsetko co mas k tomu Treasure Hunter pripadne aj s nejakym komentarom na [email protected].
                Re: Coin Check
                It simply disconnects the discrimination pot and puts a fixed resistor in the circuit instead. This resistor value is equivalent to setting the disc pot to about "6" or so where only coins are detected.
                  Rerobaj nesto drugo
                  ostavi se bandida...nije vredan paznje , ako zelis semu zaista dobrog aparata kontaktiraj me.....u klasi je fishera CZ20 i ima mesta da se uradi jos i vise
                  pozdrav s juga
