Here is the schematic for an H bridge which uses all N channel FET's. High side drive switching is made possible by the use of a charge pump which provides an extra positive supply. I used the transmit timing square wave to drive the charge pump. A 555 has no trouble driving it. I used a separate receive coil but it should be easy to run into a standard coil amplifier circuit.
