HELP ME OUT minelab Relic Hawk
  • HELP ME OUT minelab Relic Hawk
    hello i have that dectector orginal here at home
    now if i set it on i heard grat noise, als i put the coin in air
    can somebody help me on the shematic and the board layouts or circuits diagram
    i have i friend that will searh for the error
    i think that somebody on the forum have it
    PLEAS PLEAS help me out
    my detect cost me about 1100 dollars
    i have clean it and also have charger the battery to full
    THANKS Guys
    i am from Belgium
    Re: HELP ME OUT minelab Relic Hawk
    I was repaired it couple of times. They have very bad PVC isolation in coil cable, and you can try it first (usually close to detector military jack).
    Also, you can try two adjust helicoid potentiometers 100k on board (I had split once).
    I haven?t schematic for it.
    It is a lot of money, and he not rate for it. On my polygon, he wasn?t felt copper pan 22cm diameter, 50 cm deep in ground, with 40 cm DD coil.
    Good luck with it.
    Jackdetect.
      I am looking for a owners manuel for a Super Relic Hawk probably about 10 years old. Can anyone help me?
