Air test movie
  • Air test movie
    Quarter at >15 inches. See link at bottom of this page.
    http://bellsouthpwp.net/r/a/ratcity/downloads.html
    What detector?
      Detector is Troy X3 with 9" coil.
      I got pretty much the same results with the 7" coil.
        gold bar 12.5kls at 40ft. i need this detector.
          X3
          Troy X3 Carl.
          I use the 9 inch coil.
          However I have the same results with the stock X3 7" coil which is pretty amazing.
          You have to get in a little chatter to get 15 sometimes (in the house) but 14 is easy.
          I'm going to re-do this with the 3 coils I have (9, 7 and DD 10 x 5) and with a uMax for reference.
            Do my eyes deceive me or are you 5 years late with your reply?
            Anyway, I agree the Shadow X3/5 was a good design. I think there is an X5 laying around here somewhere, I should pull it out and give it a run.
              How many fast passes the time
                Originally posted by Goodrat View Post
                Troy X3 Carl.
                Unfortunately, that 15" turns into about 6" in many cases in actual use.. It seems as though these higher frequency machines are really hot on small, low conductors but don't penetrate so deeply in the ground. At least that is my observation withe the X5.
