SNIFFER XR-71
  • repeating some things for forgetful guys.
    https://www.geotech1.com/thuntings/s...ighlight=XR-71
    01-10-2006, 12:36 PM
    Ferric Toes
    Member
    XR-71
    Hi All,
    Interesting that the layout and board shown, is identical to that designed for the Eurodec and Woodtec detectors by Pulse Technology Ltd.
    If anyone is interested, I have three boards, loaded with resistors, capacitors, diodes and transistors, but without IC's. The boards are used and untested, and in good condition. All IC positions are socketed, so it's just a matter of plugging them in. Email me at [email protected]
    Eric.
    • SNIFFER XR-71
      Ferric Toes
      Member
      XR-71
      Hi All,
      Eric.
      KT315 , I am following your posts on this very close , so is Pulse Technology Ltd. a company from England or Germany ??? Thanks again for posting all this information today !!!..........Eugene
      • Hi guys
        would there be any type of ground balance on this unit ?????
        thanks
        • Originally posted by amtech2005 View Post
          The Company is from England (Eric is beside!!!!).
          So who is the first??????? Maybe you believe that Eric took it from Bulgarian Guys
            Hi guys
            thanks
            no... it isn't. In that PI detector... you just shield the coil if need to use a small one like 8'' or 10'' and then you HOPE will be no ground influence.
            It's very unlikely it happens really, expecially in inland soil, really rare you could gain benefits that way.
            Usually minerals in soil will totally bust your detector performances you tested on the bench: as example, I made one that can detect 1eur at 40cm on the air using 8'' fast monocoil. It turned out that on 90% of cases the detector cannot detect the 1eur coin at 22cm underground! In some cases even at 20cm, total failure!
            Hell, it seems a monster on the bench... but performance on soil are less than a very average VLF (with ground balance), not top VLF.
            The MD will AWAYS respond to hot rocks, fired stuff... etc magnetic oriented lump of crystals... with different behaviour: the more the sens on air... the more the magnetic influence and FALSE SIGNALS.
            They are not capacitive, cause of the shield effect, but magnetic related.
            Though all these limitations, they work excelent on sand... beach and in such places, you have few falses and dig sand easy... so avoid the junk in few time.
            I once found a very deep signal with a PI in inland, dug a "well" 80cm !
            Was a rusted, piece of a plane bomb...with trigger and everything... half day work to find junk!
            That's why I don't like them for inland conditions. Just big waste of time and energy... unless YOU KNOW ALREADY there must be something GOOD there... couldn't be iron trash.
            Kind regards,
              I still think Eric was the first... and then somebody cloned the schematic and sold as renewed units... different brand, country.
              I say that cause there were really few people with good understanding of PI technology at that time, and schematics is good engineering from an expert.
              Seems all informations match to say the Eric's work was copied and adjusted to new, different needs...
              Industrial detectors... changed in TH deep machines.
              That would not mean who redesigned MD was not good EE or something... just that was a remake of something else, industial device.
              So I agree with you.
              Kind regards,
              • http://www.findmall.com/search.php?3...atch_threads=0
                then to go http://www.findmall.com/read.php?34,...286#msg-130286
                and read...
                Thanks Malcolm Lear !
                JC
                Date: February 21, 2002 08:05AM
                Hi Malcolm and all,
                Thanks for this Russian website I didn't know about. I found the DeltaP (Delta pulse) to be of interest. I think it shows what Eric was talking about using diodes and sharing the cap and resistor to two monostable multivibrators (one shots) to keep the first and second sample width more are less the same. On my fully adjustable bench step up I actually use the same one shot for both samples, which can be achieved with a few logic gates and a flip flop.
                The analog chain on this design is most interesting. Appears to me to be a direct coupled no motion required design, where he is auto nulling the offsets of the amplifiers during the transmit on period. Least thats what it appears he is doing thoughout this chain. But I could be wrong. Anyone else have any comments on this design? Anyone tried this front end amplifier scheme? Or any of the rest of it. Going to have to look at this one a bit longer than most, trying to figure out the up side, down side of what is being done here. Maybe some good ideas for the free design? We should be able to come up with something a bit better than the basic. Maybe several different analog designs.
                JC
                dig the oldie logs, people. you will get the history.
                • SNIFFER XR-71
                  KT315 , Your research is alway's very accurate . And I respect your work . But we need to find the schematic and circuit-board photo's of the Sniffer XR-6. A "GERMAN P.I. METAL DETECTOR" !!!!! From a German company. A former member of this forum owns a XR-6 . But is no longer an active member of Geotech . All I want now , is just the Sniffer XR-6 information and nothing else . Everything on Delta Pulse , or the Xr-7 , Xr-71 is posted everywhere on Geotech already !!! ......So I am looking forward to any clue's or any information on this "Big Mystery" .....Thank-You.........Bye............Eugene
                  • hi people,
                    if you have a good technicial skill level and big expirience I need in your help now. I am in stage on preparation of an article on DP and Sniffer for a magazine. all schematic is clear reading for me but I need in detailed description of RX end op-amps and the used principle of integration, subtraction and storage on the op-amps.
                    magazine fees are very low in our part of world and I hope only on unselfish your help. ugly Russian would be more appreciated but any English will be also not so bad.
                    forum postings are very uninformative for good material, I regret to say it
                    best regards
                    • kt315,
                      Look at Carl's Hammerhead article. http://geotech.thunting.com/pages/me...ead/HHv1p5.pdf
                      What you are seeking for the Sniffer XR-71 is very similar to this Hammerhead article. You can find the equivalent circuits of the Sniffer XR-71 in the Hammerhead documentation where all the circuits are described in detail.
                      Look at the schematic and circuit layout for the latest version of the Hammerhead where there is a new provision to use either a mono coil or a DD coil.
                      bbsailor
                      • Thanks Bbsailor, I will follow your suggestion.
                        Hi guys
                        thanks
                        as for PI method there is not exist specificly and great hot need in ground balance. but DP was constructed by bulgarians for 'bulgarian' soil ground. these guys always say repeated us 'we have VERY hard ground anywhere here in Bulgaria' on the schematic you see this part as D9D and D6B (take my last general XR-71&DP schematic). in last part of ... hmmm.... exponencial falling delta impulse the mineralized ground will give some DC (I repeat here that on normal ground this DC will be clear zero voltage). we call this 'residual voltage level'. this level will been writen in C16, on Tr2 signal, for keeping on all 'working period' (or 'working cycle'), and will compensate this mineralized ground effect.
                        my english may be very poor for to give you clear comment, but let advanced gurus give you the light
                        yours
                        • SNIFFER XR-71
                          Hello , In very bad soil , maybe its time to experiment with a different type of search-Coil ? Not a regular single p.i. coil , but a dual configuration ...........Eugene
                          • Amtech, why dont you try "8" coil. Turns to be pretty immune to mineralization,hot rocks and black sand.
                            Regards!
                            • hello, can anybody translate a post under on english?
                              http://www.schatzsucher.de/Foren/arc...p?t-22372.html
                              Archiv verlassen und diese Seite im Standarddesign anzeigen : Suche: Bedienungsanleitung SNIFFER XR71
                              abuddi
                              30.12.2005, 15:56
                              Hallo zusammen,
                              habe gerade einen XR71 erstanden, leider ohne ausführliche Bedienungsanleitung.
                              Wäre jemand bitte so freundlich, und könnte sie mir anbieten. Englisch würde auch gehen. Vielleicht auch als Dateianhang. Die Kurzanleitung in deutsch habe ich.
                              Danke im voraus & guten Rutsch!
                              abuddi
                              Hartmut2006
                              01.06.2006, 20:32
                              Ich habe eine englische Bedienungsanleitung von der Eurodec MK-2, die auch unter dem Namen Sniffer XR 71 vertrieben wurde. Falls noch Interesse an dieser Bedienungsanleitung besteht, bitte eine kurze Email an [email protected] !
                              • excavator
                                hi all can some one advice me on where dos this divice made and dose it works for detecting gold
                                further how can defrenciat between othe elements
