2 boxxxx :)
  • HI all
    see this :
    http://www.technick.net/public/code/...nce_calculator
    can somebody tell what accurate mean this words:
    " relative permeability of the medium "
    • Originally posted by sisco View Post
      HI all
      see this :
      Relative permeability is calculated by taking the ratio of a material's permeability to the permeability in free space (air).
      For a metal detector coil (which is an air-filled coil) the relative premeability is "1".
      Here's the reason:
      The permeability of air is 1.256e-6 H/m, and u(relative) = u(material) / u(air).
      In this case, u(relative) = 1.256e-6 / 1.256e-6 = 1.
      • Hi KT315
        Many thanks for books.
        Best regards .
        • Coils tune up
          Hi Gary.
          Today i worked on coils for TR Locator.
          TX coils is 18 uH and RX coil is 22 uH ( a little higer).
          I use rg-59 has TX and RX lines.
          For TX coil i put 0.1 uF cap i serie and for RX coil 0.2 uF in parallel.
          Coils were looking each other at about 3 meters away from each other, but nothing happends, only a very small sound from my earphones.
          Gary, i not shure on how to make it work, so if you or any friend with more experience than me can help, i ll be very happy.
          Has i seaid i only have probescope from radioshack, mfj-259b and L/C meter.
          Plase let me know how to proced with this.
          Nelson
          PD: Gary, PCB and reg1117 recibed ok. Money is on the way.
          Nelson
          Hi Nelson, Not sure How you determined those 150 Turns for a Square Coil of that Size.
          Personally I Haven't found a Square Coil Calculator that works properly.
          My Square coils were actually Rectangular and only 14 Cm by 18 Cm. I just wound them by measuring the Inductance as I went.
          The Exact Inductance isn't Critical because you tue it with those Caps, But 38 mH is Kind of High.
          I would definately Unwind some wire.
          Gary
          • nelson, mira, yo creo que el sevzirfo tiene una gran dificultad por su transmisor tan complicado, yo te sugiero que veas si ya esta funcionando en su circuito y funcion del receptor, eso lo puedes comprobar acercando el cautin soldador al embobinado del mismo receptor, se debe de percebir la senal pues el soldador manda magnetismo y es recibida
            tu problema solo es porque estas construyendo tu primer dos cajas y no entiendes bien sus balanceamientos, debes de cerciorarte de que tanto el receptor como el transmisor ya esten funcionando, el receptor tambien lo puedes comprobar acercando el circuito junto a una tv, el transmisor lo puedes probar acercando el circuito a un radio de onda corta y moviendole para sintonizar y tratar de hallar donde es recibida ya la senal, no olvides que es muy importante que tu detector tenga los capacitores que van junto a las bobinas que esten apropiados a las frecuencias y que estos sean de igual valor en el transmisor como en el receptor, prueba con diferentes capacitores en paralelo con los embobinados
            yo creo que deberias de tratar primero de construir un dos cajas mas sencillo como esos de dos circuitos aparte, yo te sugiero el que presento gary en su proyecto de dos cajas, ese que el receptor es de siete o mas transistores, o que hagas primero el sencillo receptor que presento esteban aqui, mira ahorita yo no tengo funcionando bien mi laptop ya que esta infectada de virus, y estoy escribiendo con la laptop vieja, y es pentium 1 y no puedo accionar rapido pero si puedo te mando unos circuitos sencillos de dos cajas, como te digo solo el primer dos cajas es dificil despues es muy facil saber en que se basa su funcionamiento, asi que estoy contigo, para ayudarte lo que pasa es que he andado trabajando mucho y no puedo entrar como tu veras estoy escibiendo ya muy noche, y es que no he podido comuncarme pero aqui estamos para comunicarnos, yo creo que ya estas cerca para que funcione el sevzirfo pero te conviene empezar al mismo tiempo otro muy sencillo
            ok nelson estamos en contacto saludosssssssssssss
            detectoman
            • nelson mira en mi receptor la senal es comprobada si acerco un cautin electrico soldador al paquete de baterias, o a la bocina, asi puedes comprobar si el receptor esta ya funcionando, como te digo trata primero de armar un transmisor de esos sencillos de un solo transistor, y comprueba su oscilacion sintonizando un radio de onda corta, se debe de oir un zumbido proporcional a la sintonia obtenida, claro esta tal comprobacion se hace con el embobinado y capacitor de este ya conectados, prueba con diferentes capacitores, y comprueba si llega corriente a las salidas de ese transmisor, te debe de dar arriba de 10 voltios, en cuanto al receptor primero arma uno sencillo o mas o menos antiguo y lo compruebas ya con su bobina y capacitor y bocina acercandolo a la television como te dije
              ok un saludo nelson, y ya veras que lo logras solo ten calma y sin prisas
              mira el dos cajas que yo he hecho no te lo puedo compartir pues es hecho sobre prueba y error, y es de manera lirica y esta muy modificado, y dibujar su circuito no seria facil ya que es una marana de cables, y conexiones, y la verdad no se dibujar, pero te digo que he tenido mucho logro, pues recibo la senal a una distancia de doce metros en aire caja a caja claro separadas y de frente, para mi no ha sido tambien facil pero yo soy un investigador muy empecinado y muy minucioso y he hecho este circuito a base de pruebas y cambios, y lo he conseguido pero he batallado pero he aprendido mucho ok un abrazoteeeeeeeeeeeeeeee
              detectoman
              • Coils
                Hola detectoman y gracias por responder.
                Bueno, la verdad es que he tenido uno que otro inconveniente en este proyecto.
                Primero dime si está bien al usar cable rg-59 para transmitir las señales de RX y TX, o mejor uso algún cable paralelo?
                Si, el transmisor funciona como indica el esquematico, de hecho tengo señal en las otras frecuencias también.
                Ayer medi las bobinas y obtuve lo siguiente:
                TX: 18 mH
                RX 22 mH
                En cuanto a los valores de las capacidadesd, tengo que corregirlos y colocar 0.27 uF para la transmision y 0.33 uF para la RX. Es en este punto donde creo está el problema.
                Otra cosa, solo escucho un bajo sonido en los audifones y cuando toco con mi mano los capacitores tanto de TX como de RX, el tono cambia un poco.
                Bueno detectoman, gracias por tu información y espero poder comentar más muy pronto.
                Atte.
                Nelson
                Hello and thanks detectoman.
                Good, the truth is that I have one disadvantage in this project.
                First tell me if is correst to use cable well rg-59 to transmit the signals of RX and TX, or better use some parallel cable?
                The transmiter realy works as indicates the schematic, in fact I also have signal in the other frequencies.
                My coils values are:
                TX: 18 22
                mH RX mH
                Capacitor values must be 0,27 uF for the transmission and 0,33 uF for the RX. It is in this point where I think my problem is.
                Another thing, I listen to a low sound in my phones and when I touch caps with my hand the tone changes a little.
                Ok detectoman, thanks for your information and I hope to be able to comment more soon.
                Nelson
                detectoman
                • Coils were looking each other at about 3 meters away from each other, but nothing happends,
                  on 3 meters your schematic gets all your home. real distance between coils must be only 70-80-90 sm. be aware that as MORE the distance you will have so MORE TARGET (F(mass, volue etc.)) your schematic will reach of.
                  it is very simple Principle for an understanding!
                  • Nelson: The Only reason you may Initially put the coils 3 meter apart is to See what Distance the your signal is travelling and still being detected.
                    With This Distance, you may also try to Change the values of the Series cap on the Transmit coil and also the Parallel cap on the Recieve coil to see if you can Increase the Signal to get a Better distance.
                    However, in a real working application, as stated by KT315, 70 to 90 centimeters is probably a good distance between coils.
                    Since I Don't understand Spanish, I'm Not sure what all was Discussed in those other posts.
                    I Hope you got some Useful Help.
                    • nelson, yo creo que para prevenir errores seria mejor que no pusieras cables blindados, sino cables algo separados, y tambien creo que la barra entre las dos bobinas la pusieras de madera
                      quiero decirte que creo que es mas dificultoso ese detector que precisa de un solo circuito y las mismas baterias y en ambos bobinados para funcionar, ya que necesita de un exacto equilibrio y eso es ya mas dificil conseguirlo
                      y creo que es mas simple el de dos cajas completamente separadas o sea tanto trasmisor como receptor separados y con diferentes baterias
                      por favor traduce para los demas
                      un saludote
                      detectoman
                      • para okantex acerca del detector raro hecho por un japones
                        nelson o esteban o max por favor traduzcan para okantex y los demas
                        hola okantex escribo aqui porque no encuentro el panel donde trataste acerca del detector japones raro ese de toroidal cuadrado y bobinados
                        mira, estuve estudiando ese detector que presentas, y veo que la caja grande es un receptor amplificador, de ella debieron salir como 6 cables que se hiban a conectar directamente a la otra caja que se usa con el plato de rastero, yo creo que alli se encuentran juntos la bobina de pulsos enmedio de la antena cuadrada que la conforma el toroidal, y veo que en la caja de amplificacion grande son mandadas distintas frecuencias o diferentes oscilaciones para exitar los diferentes metales, segun la frecuencia de las resistencias escogidas es la senal mandada y lanzada hacia abajo, en conjuncion con residuos magneticos, entonces esa senal rebota en el metal y regresa exitando a su vez los enrollamientos del toroidal, algo parecido a la bobina receptora, aunque alli sea mas complejo, aqui vemos unos circuitos sumamente simples pero en su epoca esos transistores heran de muy poca vida, y mas inestables es por eso que tal aparato no trascendio, pero fue un detector muy avanzado para su epoca, y creo tambien que se podia cambiar la frecuencia del bobinado del toroidal, o sea para que fueran las dos senales similares tanto la de activacion como la de eco toroidal, en cuanto a el snozzer de piezo era la que daba la indicacion de que la senal estaba rebotando apropiadamente, veo que tenia de los mas efectivos complementos y su diseno verdaderamente fue muy preciso,en cuanto a volver a armarlo creo que llevaria mucha experimentacion ya que tenia algunos especificos transistores que ya no se consiguen, de todos modos creo que tendria tambien interferencias y le ha de ver faltado bastante estabilidad dados sus complementos, pero como te digo es un aparato propio del genio de inventiva de los japoneses
                        rehacerlo seria una labor titanica pues se tendria que poner a punto y esos secretos de transmision y recepcion conjunta son una verdadera hazana
                        les mando un abrazo
                        por favor que alguien traduzca para okantex
                        detectoman mexico
                        • Coils
                          Ok Gary, kt-315 and detectoman.
                          One more question, how i can know if the signal is traveling to the receiver, because my tr locator does not have a signal meter. So is there another way to know if the signal is reaching the receiver.
                          Also can anyone tell me if i can do the coils with toroids or ferrites.
                          Nelson
                            Nelson
                            Hi Nelson, A Meter on the board would be Helpful.
                            You Could use a Multi-meter, Digital or Analogue (either in Volts or Micro-Amps) for temporary testing.
                            I have hundreds of Small Vu meters that will work if you want one.
                            Unfortunately, no extras with the zero in center scale Like the one I showed in my setup.
                            No, I doubt Torroids would Work at All.
                            A Ferrite Rod or Pot Core, MIGHT WORK, But Definately Not for Great Distances.
                            Gary
                            • Tr locator
                              Hi Shahab.
                              How is your tr locator working?
                              Any success?
                              I also had lots of thinks to do, so i hope this weekend i can try it after i place an S meter.
                              Nelson
                              Originally posted by Shahab View Post
                              Hi Nelson.
                              I am busy these days . . .
                              I have 2 exams on friday & saturday.
                              • Hi Nelson
                                I didn't work on TR but i think it's OK.
                                Coud you fix your circuit on 2048Hz?(Does L-C tank resonate on 2048Hz?)
