2 boxxxx :)
  • Originally posted by okantex View Post
    is there anyone who knows this machine.I heard it is used in russian army.
    I searched but can not find anything about it.mine was stolen .it was really good that we find gold coin at 4 meters dept.I want russian friends help.
    Hi okantex
    where you are reading about 4 m dept?
    • Okantex 3 box system
      WM6, The radio receiver is only a box of Okantex System. This 3 box system. To radio is connected a box with electronics processing demodulated signal and buzzer. The main part is transmitter with very odd antenna design. It is powered with 9V battery and 4 cells x1,5V. It seems like metal detector. See postings #12 and #39.
      • Hi Nelson, any further development on your TR locator project?
        • you see the 006 , under it there are three lines controled by tuning pots. the owner told me that He was getting dept from that part.
          can you give original user informations of this radio , I mean funtions of buttons above the box and funtion of parts ,does it for LW , AM ,FM etc?
            Hi okantex
            This receiver is designed to work in all radio bands (mean: LW, SW, MW and UKW). You can replace it with any other all band receiver, no need to weight 9 kg as Leningrad.
            Here some google translations:
            The radio is designed to work in all radio bands taken
            GOST. Stereo program can be taken in the range of VHF. Reception -
            nickname has two internal magnetic antenna for reception of IR, S-band and the -
            leskopicheskuyu for admission to the HF and VHF bands. HF range is divided into five sub -
            ranges. Actual receiver sensitivity in the IR range of 0.8 mV / m, S 0,5
            mV / m in the range of HF 150 mV and in the UHF range of 10 mV. Selectivity in provisions
            NII''a narrow strip of''equal to 56 dB. Band reproducible sound frequency wavelength range,
            tries LW, SW, at the local position of the switch''method''is 80 ... 6300 Hz, in dia -
            pazone VHF 80 ... 12000 Hz. Rated output ULF not less than 1 W, the maxi -
            The maximum 1,5 Tues When AC power output maximum power in
            ity will be up to 2,7 Tues Consumption from the network - 15 Tues Dimensions radioreception -
            ka''Leningrad-006-stereo''- 390h394h164 mm. Weight - 9 kg. Retail price of 314 rubles.
            Here can you find more russian instructions in *.djvu format:
            http://www.rw6ase.narod.ru/l/leningr...ingrad006.html
            • Front panel
              L006 Controls
              Front panel
              1. Volume control for headphones
              2. Stereo balance control
              3. Stereo decoder on/off - key
              4. AFC on/off - key
              5. DX/Local - key
              6. Narrow band - key
              7. Wide band - key
              8. FM - key
              9. SW2 – SW5 - key
              10. SW1 - key
              11. MW2 - key
              12. MW1 - key
              13. LW - key
              14. Telescopic antenna
              15. SW2 - key
              16. SW3 - key
              17. SW4 - key
              18. SW5 - key
              19. Power on/off - key
              20. Tuning SW2 – SW5 and FM
              21. Audio tremble - control
              22. Tuning LW, MW1, MW2 and SW1
              23. Audio bass - control
              24. “Speech” - key
              25. Volume control
              26. “Solo” - key
              27. Gramophone on/off - key
              28. Tape recorder on/off key
              29. Lighting at battery powered mode
              30. Fixed stations: FM1, FM2, FM3
              31. Tune FM1, FM2, FM3 - controls
              32. Tuning meter and battery check
              33. Stereo indicator
              34. Handle
              • Addition
                Rare panel
                1. Cover for audio connectors
                2. Earphone connector
                3. Loudspeakers connector
                4. Headphones connector
                5. Gramophone connector
                6. Tape recorder connector
                7. Spare parts compartment cover
                8. Spare parts compartment
                9. Mains supply compartment cover
                10. Connector for mains cord
                11. Fuse
                12. Mains voltage switch
                13. Antenna connectors cover
                14. FM antenna connector
                15. Ground connector
                16. LW, MW and SW antenna conn
                17. Antenna connectors compartment
                18. Internal/external antenna switch
                • Frequencies in L006
                  L006 frequencies
                  Received bands
                  LW: 150 - 408 KHz
                  MW1: 525 - 1300 KHz
                  MW2: 1300 - 1605 KHz
                  SW1: 3,95 - 6,2 MHz
                  SW2: 5,95 - 6,25 MHz
                  SW3: 7,07 - 7,38 MHz
                  SW4: 9,35 - 9,85 MHz
                  SW5: 11,6 - 12,1 MHz
                  FM: 65,8 - 73 MHz
                  IF bandwidth
                  AM IF =468KHz
                  Local receive 13 – 15KHz
                  Wide band 9KHz
                  Narrow band 5KHz
                  FM IF=10,7MHz
                  No data for bandwidth
                  The receiver is produced since 1978. It weights near 10kg!
                  • Where the buzzer is connected?
                    The buzzer can be connected to meter P1.
                    • Excellent mikebg, thank you.
                        Is it possible to build this project today? such as are those parts still available?
                        • yes thanks friends ,
                          btw happy new year to all .
                          as told to me frequency selection buttons 8-13 were used to select metal type after stopping buzzer box beepss.when pioner ( detector ) find metal , it also starts beeping together with buzzer .
                          than user stops buzzer and push frequency selection buttons to f,ind metal type ,
                          but if you ask me it must be like that ,
                          detector part must be a passive receiver ,having highly directional receiver and must be wideband receiver.just enough to get phase shift ,
                          and after finding target it must emit the frequency to radio ,
                          buzzer box must receive this signal ,
                          signal received by detector is 90 degre shift of any LW or AM signal propageted by stations.
                          this received frequency must be shifted 90 and checked by shifting ratio of different metal which must be adjusted manual by scope on the bench.
                          so that , frequency button will be metal selection buttons after calibrating them by scope.
                          I think you could analyse it better than me,
                          we need to hav brain storming , what about your ideas
                          kind regards
                          Okantex
                          • Has anyone successfully built the 2 box by charles? I need help for the replacement for the transistor at the TX which is the 2N2924.
                            • i desing pcb for varna.
                              i think this detector power full. told sascho this detector can be detect target 15cm *15cm in 1 meter.
                              anyone want pcb tell me yahoo adress until send
                              • "Okantex System" Project
                                REMI group
                                A group of amateur radio designers, having as hobby to redesign, revise, reinvent and rediscover the electromagnetic induction :-)
                                Our slogan is: come up with something more perfect!
                                Okantex System
                                Virtual Project
                                OBJECTIVE:
                                The project aims to reinvent a metal detecting system, which detected a coin at depth 4m (400cm).
                                NAME:
                                The name of the project comes from Okan Aydin (okantex) - the man who has described such system. (Americo Vespucci has described a continent, so it is named after him :-)
                                REFERENCES:
                                1. Geotech Forums>Coils>Eddy Currents
                                2.Geotech Forums>Technology>Tech Forum>2boxxxx-
                                3.
                                START DATE: The project started on 081109 with collection of information.The collection will continue with discussion in Geotech Forums.
                                DESCRIPTION(see sketch below):
                                1. The OkantexSystem consists of three unitsas shown in the sketch
                                U1 looks like hand held metal detector,
                                U2 looks as portable heavy stereo radio receiver,
                                U3 is a box connected to U2. It contains pcb and a Buzzer.
                                First operator moves U1.
                                Second operator at U2 and U3 remain immovable.
                                It plays with buttons to see dept and discrimination of metal.
                                Is this correct?
