2 boxxxx :)
Okantex 3 box system
WM6, The radio receiver is only a box of Okantex System. This 3 box system. To radio is connected a box with electronics processing demodulated signal and buzzer. The main part is transmitter with very odd antenna design. It is powered with 9V battery and 4 cells x1,5V. It seems like metal detector. See postings #12 and #39.
you see the 006 , under it there are three lines controled by tuning pots. the owner told me that He was getting dept from that part.
can you give original user informations of this radio , I mean funtions of buttons above the box and funtion of parts ,does it for LW , AM ,FM etc?
This receiver is designed to work in all radio bands (mean: LW, SW, MW and UKW). You can replace it with any other all band receiver, no need to weight 9 kg as Leningrad.
Here some google translations:
The radio is designed to work in all radio bands taken
GOST. Stereo program can be taken in the range of VHF. Reception -
nickname has two internal magnetic antenna for reception of IR, S-band and the -
leskopicheskuyu for admission to the HF and VHF bands. HF range is divided into five sub -
ranges. Actual receiver sensitivity in the IR range of 0.8 mV / m, S 0,5
mV / m in the range of HF 150 mV and in the UHF range of 10 mV. Selectivity in provisions
NII''a narrow strip of''equal to 56 dB. Band reproducible sound frequency wavelength range,
tries LW, SW, at the local position of the switch''method''is 80 ... 6300 Hz, in dia -
pazone VHF 80 ... 12000 Hz. Rated output ULF not less than 1 W, the maxi -
The maximum 1,5 Tues When AC power output maximum power in
ity will be up to 2,7 Tues Consumption from the network - 15 Tues Dimensions radioreception -
ka''Leningrad-006-stereo''- 390h394h164 mm. Weight - 9 kg. Retail price of 314 rubles.
Here can you find more russian instructions in *.djvu format:
http://www.rw6ase.narod.ru/l/leningr...ingrad006.html
Front panel
1. Volume control for headphonesL006 ControlsFront panel
2. Stereo balance control
3. Stereo decoder on/off - key
4. AFC on/off - key
5. DX/Local - key
6. Narrow band - key
7. Wide band - key
8. FM - key
9. SW2 – SW5 - key
10. SW1 - key
11. MW2 - key
12. MW1 - key
13. LW - key
14. Telescopic antenna
15. SW2 - key
16. SW3 - key
17. SW4 - key
18. SW5 - key
19. Power on/off - key
20. Tuning SW2 – SW5 and FM
21. Audio tremble - control
22. Tuning LW, MW1, MW2 and SW1
23. Audio bass - control
24. “Speech” - key
25. Volume control
26. “Solo” - key
27. Gramophone on/off - key
28. Tape recorder on/off key
29. Lighting at battery powered mode
30. Fixed stations: FM1, FM2, FM3
31. Tune FM1, FM2, FM3 - controls
32. Tuning meter and battery check
33. Stereo indicator
34. HandleAttached Files
Addition
1. Cover for audio connectorsRare panel
2. Earphone connector
3. Loudspeakers connector
4. Headphones connector
5. Gramophone connector
6. Tape recorder connector
7. Spare parts compartment cover
8. Spare parts compartment
9. Mains supply compartment cover
10. Connector for mains cord
11. Fuse
12. Mains voltage switch
13. Antenna connectors cover
14. FM antenna connector
15. Ground connector
16. LW, MW and SW antenna conn
17. Antenna connectors compartment
18. Internal/external antenna switchAttached Files
Frequencies in L006
LW: 150 - 408 KHzL006 frequenciesReceived bands
MW1: 525 - 1300 KHz
MW2: 1300 - 1605 KHz
SW1: 3,95 - 6,2 MHz
SW2: 5,95 - 6,25 MHz
SW3: 7,07 - 7,38 MHz
SW4: 9,35 - 9,85 MHz
SW5: 11,6 - 12,1 MHz
FM: 65,8 - 73 MHz
Local receive 13 – 15KHzIF bandwidthAM IF =468KHz
Wide band 9KHz
Narrow band 5KHz
No data for bandwidthFM IF=10,7MHz
The receiver is produced since 1978. It weights near 10kg!Attached Files
Where the buzzer is connected?
The buzzer can be connected to meter P1.Attached Files
yes thanks friends ,
btw happy new year to all .
as told to me frequency selection buttons 8-13 were used to select metal type after stopping buzzer box beepss.when pioner ( detector ) find metal , it also starts beeping together with buzzer .
than user stops buzzer and push frequency selection buttons to f,ind metal type ,
but if you ask me it must be like that ,
detector part must be a passive receiver ,having highly directional receiver and must be wideband receiver.just enough to get phase shift ,
and after finding target it must emit the frequency to radio ,
buzzer box must receive this signal ,
signal received by detector is 90 degre shift of any LW or AM signal propageted by stations.
this received frequency must be shifted 90 and checked by shifting ratio of different metal which must be adjusted manual by scope on the bench.
so that , frequency button will be metal selection buttons after calibrating them by scope.
I think you could analyse it better than me,
we need to hav brain storming , what about your ideas
kind regards
Okantex
"Okantex System" Project
REMI groupA group of amateur radio designers, having as hobby to redesign, revise, reinvent and rediscover the electromagnetic induction :-)Our slogan is: come up with something more perfect!Okantex SystemVirtual Project
OBJECTIVE:
The project aims to reinvent a metal detecting system, which detected a coin at depth 4m (400cm).
NAME:
The name of the project comes from Okan Aydin (okantex) - the man who has described such system. (Americo Vespucci has described a continent, so it is named after him :-)
REFERENCES:
1. Geotech Forums>Coils>Eddy Currents
2.Geotech Forums>Technology>Tech Forum>2boxxxx-
3.
START DATE: The project started on 081109 with collection of information.The collection will continue with discussion in Geotech Forums.
DESCRIPTION(see sketch below):
1. The OkantexSystem consists of three unitsas shown in the sketch
U1 looks like hand held metal detector,
U2 looks as portable heavy stereo radio receiver,
U3 is a box connected to U2. It contains pcb and a Buzzer.
First operator moves U1.
Second operator at U2 and U3 remain immovable.
It plays with buttons to see dept and discrimination of metal.
Is this correct?Attached Files
