Electronic dowsing rod
This topic is closed.
  • Electronic dowsing rod
    Hello people, I am new to this forum.
    Does anyone tryed the (tone detector) electronic dowsing rod?
    Electronic Dowsing Rod
    Some people have heard of the term "Dowsing" before and
    some of the wild stories of its use and effectiveness. Typically it
    would entail using a forked branch and holding it in outstretched
    arms. If you are attempting to find water, then the dowser would
    simply clear his mind and concentrate on water as intensely as
    possible. The dowsing rod should begin directing you to the
    nearest source of water. It will dip or turn and point to the water
    with an amazing success rate. You can actually dowse for
    virtually any materials such as water, mineral deposits, precious
    metals, etc....
    Research
    While the subject of dowsing has suffered greatly from disbelief
    in this country, the USSR and Czechoslovakia have spent a lot
    of time and money to investigate its uses.
    Today dowsing is a legitimate field of study in the USSR. Major
    geology schools in Leningrad and Moscow have large research
    groups consisting of geologists, geophysicists, and physiologists
    hard at work studying the concepts of dowsing.
    The dowsing rod is declared to be the simplest Electro-
    physiological instrument because the wooden fork acquired
    super-sensitivity to underground objects when held in human
    hands. And, when they measured the force that dipped or raised
    the tip of the rod, they found it ranged from 100 to 1000 grams
    per centimeter.
    How the Electronic Dowsing Rod works
    The electronic dowsing rod is basically a tone detector capable
    of detecting "tones" in the frequency range from 0-.01 Hz to 500
    KHz. The 567 chip contains a phase-locked loop. When the
    input frequency matches the center frequency of the chip, pin 8
    goes low and allows the LED to glow.
    The input frequency is the signal picked up by the dowser’s
    body, fed to the 567 through pin 3. The potentiometer R1, sets
    the frequency of the chip. This frequency can be determined by
    the formula:
    F=1.1/RC
    The 567 can be adjusted to detect any input between the ELF
    band well below 1 Hz, all the way to the AM radio broadcast
    band. Quite a valuable little chip for the serious dowser. The
    natural period or long-wave frequency of almost all materials
    and minerals fall in this spectrum. Of most interest will be those
    ELF waves below 10 Hz.
    The electronic dowsing rod can be calibrated by using a pointer
    on R1 and making a notation of its position when the LED lights
    up. You will find water at one setting, silver at another, and so
    forth. In theory, you can detect virtually any material if the
    device is calibrated properly for each substance. You can
    calibrate the device by holding these and other substances in
    your hands while the dowsing rod is in operation.
    When detecting the extremely low frequencies, it will take the
    567 a second or two to lock on, so give the device time to
    respond. Don’t be in a hurry. Take your time when calibrating or
    using your electronic dowsing rod.
    All substances, organic and inorganic, give off ELF waves. And
    most substances have one certain ELF wavelength that is one
    particular substances signature. The human body, because of it's
    many miles of nerve fiber, is a natural antenna for picking up
    these ELF waves.
    Before you start you’re dowsing, let me remind you not to wear
    gloves while dowsing. The gloves may insulate the energy. It's
    important to use your bare hands.
    Construction
    Bore a hole in each side of the project box to accommodate the
    length of No. 6 copper wire. Use rubber grommets in the holes.
    Make sure that enough wire protrudes on each side so that you
    can grip it firmly in both hands. Assemble the IC, resistor R2,
    and capacitors on the PC board. Drill holes for the potentiometer
    shaft, LED, and on-off switch, and then mount them on the front
    of the project box. Slip the assembled PC board into slots in the
    project box and wire in the LED and the pot. Push copper
    dowsing rod (No. 6 copper wire) through the holes provided and
    solder a lead from the copper rod to Pin No. 3 of the 567 IC.
    Mount the battery holder, double check you’re wiring and insert
    the battery. You are now ready to dowse.
    Parts List
    B1- 9v battery
    C1- 2.2uF capacitor
    C2- 1uF capacitor
    C3- 0.1uF capacitor
    IC1- 567 tone decoder
    LED- light emitting diode
    R1- 100k potentiometer
    R2- 1k resistor
    On-off switch
    Length of copper wire No.6
    Project case
    lostfox
    Hi lostfox
    didi you use this rod before?
    can you sent it's picture
    how to handle it?
    it does not look like two rod dowsing
      No I haven't try it. That's why I am asking if someone knows anything about it. A friend email me that project which he said is working perfectly. I actualy need a differend kind of machine for my case, which I 'll explain in later posts.
        I have used the 567 in Many projects and I really doubt in this circuit that your body could achieve the the required input voltage to properly trigger it at any real frequency.
        Also consider your body is constantly being Bombarded by many RF frequencies as well as 50 and 60 Hz. These are very high powered signal, compared to what any metal may Emit.
        Maybe the IC would get a bit higher voltage if that ground symbol on the schematic was actually a wire attached to a GOOD, "true earth ground".
        Also based on the fact that your using a copper rod and if it really did work, Why wouldn't it just always show as copper?
        Sounds really fishy.
        Just my 2 cents worth..........Gary
          What comes first to my mind is that if that 100k potentiometer is controlled by some microcontroller, we could make a scan of all frequencies.
            According to 567 datasheet 15mV..20mV is the smallest detectable voltage.
            Healthy cell voltage maybe even 70mV
            http://www.myholistichealthshop.com/BioEnergyMeter.html
            Here is some other writing about body voltage:
            http://pages.prodigy.net/unohu/electro_bvoltage.htm
            Perhaps a petrovoiltaic rock could be used too which could generate upto 400mV.
            Maybe that's why some dowsers meditate before dowsing -> to rise the body voltage..
              according to schematic
              what is the total batary?
              9+9=18volt , because there are two cells in schemetic
                Yes Somewhat True, But those are "DC Voltages in the Body". NOT AC.
                Frequencies. The 567 Requires AC Frequencies to Trip at a Frequency.
                Unregistered Guest
                Just because he shows a Symbol for two cells does Not mean there are Two 9 volt Batteries. It only states one battery. But either way it wouldn't change the operation of the circuit.
                  Hi Lostfox
                  can you get more info from your friend for us.
                  it looks interesting.
                  is he useing this machine?if so how he pinpoints the target ?
                  did he find any metal object with it?
                    He is a profesional dowser, He use to search for "anything", water gold treasures, people bodies for police, etc. He don't even need a dowsing rod to work. He born with the power and he practice many years with almost 100% success.
                      Hi lostfox
                      okay he does not not any rod?that is not a problem for him.
                      but us it is still problem.I wonder how to use it?
                      how to find target 's direction and pinpoint it.how to measur depth.
                      can it differ only written elements on drawing.or gold ,copper.iron ..etc.
                      when does led emit light ?when it finds objects direction from away (like 10m ,100m) or when user stands on it.
                        and also what is the lenght of copper wire
                          Research
                          per centimeter.
                          the formula:
                          F=1.1/RC
                          these ELF waves.
                          Construction
                          lostfox
                          Hi. I constructed it and maybe today or tomorrow i will try to test it.At the garden of my house the led indicates when the potensiometer is full left for water detecting. At every else position the led dont lights. I will go at the Farm to test it and after it as Ivconic says the 5Kgr hammer is ready for its Work
                            anybody please make traduction in spanish for my of this article of geo and the total page on this important report of answers
                            thanks detectoman
                            bayyyyyyyyyyyyyyyy
                              jejejeje hamer of 50 k?????? have in mind destruct algo . whatttttttttttttttt
                              detectoman
