Sources of noise
  • Sources of noise
    Hello,
    I'm interested in external Electromagnetic noise measurements taken out in the middle of the California or Arizona or Nevada desserts. Please note that I am not referring to hot-rock noise that comes from a metal detector transmitter. I'm gearing to head out to the desert in a few weeks to do some measurements but would appreciate as much data as possible. Basically I'll have an op-amp circuit with a bandpass filter hooked up to a multimeter-- nothing fancy, lol. So this is just signal receiving-- no transmitting. It's the external noise that is of interest. In other words, any noise except the noise that comes from your circuit. I understand that op-amps generate over 1nv/SqrtHz-- typically 5 to 15 nV/SqrtHz. Lets say you have a typical 16" coil. Does typical desert noise exceeds op-amp noise? How often is external noise lower than op-amp noise?
    Frequencies of interest range from 500 Hz to 100,000 Hz. So the question is, where does the dominating noise in these desert areas come from and what's their strength? Any voltage levels, coil size, number of turns on coil would be great, but any data is appreciated even if it's your best guesstimate and you do not have any specific numbers. Do you think the noise came from below, above, north, south, east, west? Is it terrestrial noise or manmade noise? I'd presume that it is terrestrial noise. Although I'm not sure how much noise you would get from far away radio stations and power lines in the 500 to 100,000 Hz range. Perhaps there are underground power lines, but how common is that.
    Here are some noise sources:
    1. Atmospheric noise. This changes a great deal from day to night.
    2. Galactic noise.
    3. Thermal noise. Caused by vibrating electrons in all matter and covers the entire frequency spectrum.
    4. Radio broadcasting. This includes everything from cell phones to radio stations to even household appliances. Of course this noise might be negligible out in the middle of the desert. I'm wondering on average just how close to a city one must get before this noise dominates.
    5. 60 Hz Power lines.
    6. Noise from vehicles such as cars, motorcycles, and planes.
    7. Satellite noise.
    8. Solar noise.
    I'm thinking that #3, thermal noise, is extremely low. Obviously electronic components, with exception of perfect capacitors and inductors, possess thermal noise which covers the entire frequency spectrum. #3 thermal noise is mentioned because the vibrating electrons in the ground actually cause noise. Although I'm predicting that ground thermal noise is extremely low. The basic thermal noise power equation is (4 k T B).
    I'm guessing that #4 radio broadcast noise is locatable by pointing the coil up toward the horizon and directed toward the source.
    Thanks,
    Paul
    I'd like to add that although I have not taken any measures yet it seems that Atmospheric noise should be the dominating noise in these dessert areas, no? I'm curious if say a 16" diameter 100-turn coil would pick up more noise in the 500 to 100,000 Hz range than op-amp noise.
    Paul
      Originally posted by Unregistered
      Hello,
      2. Galactic noise.
      7. Satellite noise.
      8. Solar noise.
      Thanks,
      Paul
      May I ask - why?
        It's for metal detecting research.
        Paul
          There is a thread in the remote sensing forum that is investigating these exact signals that you are interested in. A german experimenter built some home-made test apparatus and was amazed at the signals he found on his oscilloscope. This experimenter gives details about his testing equipment.
          I suspect that in addition to the natural signals you pick up, you may also find a large amount of noise from man-made transmissions, from high voltage power transmission to low frequency submarine communication signals. There is reasearch to suggest that magnetic storm activity on the sun has an influence on other noise signals that you might pick up.
          See details at these links:
          Ivconic's ElectroMagneticFieldAnomalyDetectors thread: http://thunting.com/geotech/forums/s...d.php4?t=11431
          German experimenter's website links:
          http://www.vlf.it/kurt/elf.html
          http://www.vlf.it/Schumann/schumann.htm
          http://www.vlf.it/below150/below150.htm
          http://www.vlf.it/parmigiani-frozen/frlight.htm
          Another site found by Esteban with lots of information on strange signals: http://www.vlf.it/
            About rare signals and other VLF stuff, found on German PI forum:
              Here is a link that shows how you can use a laptop computer with a microphone input to make a graphic display of EM frequencies in the audio range (0 - 24000 Hz). This page shows a link to a free download that will make a frequency spectrum graph on the laptop screen in real time. This method will detect these low frequency electromagnec waves as well as locate where they are coming from via radio direction-finder methods. The project requires no cost except a little copper wire for a coil, and possibly a small amplifier stage if you need more sensitivity. http://www-user.uni-bremen.de/~ews2/RDF_project.html
                It Should also be noted that this 0 to 24 kHz frequency response is not near as good as a real oscilloscope.
                Being Especially Poor on some audio cards.
                Gary
