You owned a Pro before-- is it more sensitive to nickels than the Superpro? Thanks for any info Thanks
Carl need info please What is the difference between the AH PRO AND SUPERPRO?
A.H.Pro
Super Pro Fine Tuner was the deepest seeking Pro model. Weighed 1lb more than the Pro 2 Automatic and Pro 2 Fine Tune.
Discrimination extended to take out bottle caps if required. Perhaps extended is not the right phrase as the low level of discrim. did not go as low as the other Pro 2's.
A meter on/off switch was unique to this model.
Brian
SUPERPRO VS. PRO, PRO-2
Thanks Brian! So the Pro and Pro-2 should have better sensitivity to nickels while the Superpro can knock out the bottlecaps. By bottlecaps I assume you mean the aluminum screwcaps and not the tin-iron cocoa- cola caps? Do all of these detectors accept other size coils as some of the early advertisements stated that the coils were not interchangeable? This is besides the fact that all of the detectors had connectors for the searchcoils and not hardwired into the control box. I believe that the Superpro is on another frequency than the Pro. Also are the Pro and Pro-2 on the same frequency? Thanks Again!!!
