64th addition to Murphy's law for the world vileness
The 63th addition to Murphy's law is: "In theory there is no difference between theory and practice, but in practice there is."
To rediscover the 64th addition, you need 64 identical coins and metal detector with TX coil placed inside the search head. Set with AIR TEST how deep the metal detector can detect a coin. Then check the following addition to Murphy's law for the world vileness:
"In no way to arrange 64 identical coins, the metal detector won't find them at twice the depth (than it can detect a coin :-)."
NOTES:
1. If you put coins in a metal container, you must put a coin in the same container when determining the detection depth :-)
2. You can make with coins a large eddy current circumference, but it is not allowed to solder them.
3. The law has not been tested with the orthogonal configuration of coils, because my big coils can not detect coins at all.
4. The law has not been tested with a large placed on the ground TX loop, because I do not have a suitable metal detector. However, soon we will do a test because we know a treasure hunter who uses SuperScan, designed by Eric Foster.
NOTES:
