Cache Test
  • you put the coins in metal can. detector reacts on the can. no secret.
    • in plastic bag
      • did you use silver US quarters?
          I not tried one myself. But I have been out twice with people using the Beast.
          Both times once in the Peak District (I was using a Bandido with no problems) and the other in Shropshire (I was using an IDX with no problems) the owners were having problems.
          Having to re ground balance several times and false signals. They really were having a bad time. The Peak District was water logged ground but the Shropshire one was fairly typical of around here with plough shear mixed in with coke
          Out of the 20 to 30 people taking on each rally their finds rates were towards the bottom of the scale.
          That's not to say they are bad. After all it could be operator error, just bad luck or the detector just doesn't like the type of ground we have here.
          I have never really understood blisstool as a company, the ltc27 and the ltc42 were great no nonsense detectors, but the company only seem interested in "the beast", not selling a lower spec model just seems daft to me I have heard people say "I liked the earlier simple models".
          so they are missing out on sales granted not a huge amount, but if they reintroduced the ltc27 as a base model and only sold 200 a year it would still be money in their coffers not the competition, as I understand it they are made in low volume quantities, so building a few of these for every ten ltc64's to me seems a no brainer.
          especially since the folk who would buy an ltc27 or ltc42 are not the same folk who buy the "beast", they probably assume if you want a 42 you will buy a 64, which is totally wrong and just leads to lost sales.
            no I use 30mm 5 dinara Milan Obrenovic IV
            • This coin? Says it's 37mm diameter. More like a US silver-dollar. ( Morgan / Peace type)
              https://en.numista.com/catalogue/pieces17550.html
                Y 37mm
                • whats the max depth on one 4g gold coin- roman or byzantine...35cm? or more? is the resonant frequency on this type ancient coin 8khz or 15-20khz vlf or 10-15us with pulse machine?, anyone know...
                  • You may be drifting off-topic here.
                    But to answer: A modern British Half Sovereign, 22 carat (0.917) gold, weighs 4 gram. It has a corner freq. of 11kHz.
                    • thanks skippy i know been drifting off, but i like different coins
                      • I went tru the Entire Post
                        I Have Several Caches buried
                        at 40cm
                        60cm
                        1m
                        and 160cm
                        from a few coins at 40cm
                        to full fist size jar of coins
                        a medium plastic container at 1m
                        And a bowl at 160cm
                        they all mix coins
                        been bury for 3 years
                        and I have passed several detectors mentions here
                        including relicstriker
                        only wen to the 60cm and falsing
                        the best detector I found is a Bulgarian GoldenMask Pro7
                        with a 1x1 frame
                        is able to hit my 1m mark
                        most big frame pi units Hit the 60cm
                        and i Belive the 160 is just imposible
                        • recently, I did tests of Equinox, CTX, and Atrex detectors on various conductive coins.. I was surprised that a gold coin of 4 ducats /14 grams of 24k gold/ had a significantly greater detection range than a silver dollar of the same size...Click image for larger version
                          • the vector of silver coins is quite close to the vector of ferrites and soil. the ground balance system rejects much of the signal on highly conductive silver coins. But it does not reject the foil and coins of copper-nickel alloys - their vector is about 90 degrees to that of ferrites. elementary, Watson ...
                            • an acquaintance shared - he has a test field of loam, very dense soil - it holds the water in a hole for a very long time. the buried pot gives a weak signal when the soil is moist, but the signal disappears completely when the soil is dry. The pot of coins was buried more than 17 years ago. measurements were made with a Minelab gpx 4500. what caused this ?
                              • moodz has to read.
