does a dowsing rod work for you?
    moving on to my own tests......
    Thanks for the feedback Qiaozhi and Richard....Q, yes that site shows why this is a 'you have to find out for yourself' subject......Yes R, I wonder if you'd find any proof about paranormal if you log onto Google and punched in 'Edgar Cayce'.....I think there are just stories.....14,000 of them or there abouts but no proof.
    Well, I wasted acouple hundred bucks and can now try out a chamber type dowsing rod myself.....I am making the test item 6 rolls of pennies dated before 1990.....I'm pretty sure they are all copper....
    I'm gonna bury them away from any close neighborhoods, and about a foot deep, and gonna wait for a few weeks for rain to help settle the disturbed area (hope to get a mosquito-proof suit by then!!....)........Then.....?
    Well, I will try to keep an open mind regardless of initial field tries, but I am not the most patient type.....and I am told to be just that-patient...we'll see. I AM prepared for this thing to fail to find the test target......I'm not so sure I'm prepared for any other results......I HAVE felt my possessive prospector mentality pop out before....... ........:o .......:confused: ........
      1982 was the first year of zinc pennies.
        oops
        Thanks Carl,
        I'll have to go thru the batch and remedy that........Sort of don't want to use all my old wheat cents but that may be the best way to go...... .......
          hi
          most of our friends do not believe this dowsing phenomen.also I can not understand.but in my uncle's garden there are lots of buried materials ,some are more than 8 years.
          also gold coins.
          and be sure ,maybe more than hundred person came and tested their machine there.most of them could not find gold (75cm 10 gold coin)and ones who find and get signal could not say it's type.(gold or else).they were searching in 20square meters no more.
          only a rod like in picture find it.
          it was only going to gold.
          how ? I do not know.
          It came from USA (100dolar) by post.
          not the thing in pic but looks like this.
          when there is gold ,upper part starts swinging.
          it was taken by court you know why.illegal searching.
          tip was round (ball)
          swinging part which carries ball is a little bent
          handle part a little shorter tahn this.
          İF ANYBODY KNOWS PLEASE GİVE ME ADRESS .we CAN NOT FİND İT NOW.WE FOUND ADDRESS FROM A BOOK TEN YEARS AGO.
            don't recognize
            try google.com and you will see at "simmons scientific products" at least something like it. I don't think you should buy one new......I do think you have a chance, where you are describing, to maybe witness someone using one of these things sucessfully if it is possible. I would try that route first off???!!???
              Perhaps you should try either the PMR-II of PMR=III.
              They both have a power tube which apparently contains a powerful combination of mineral crystals, together with a radiant energy stimulant. Whatever that is!!
              The PMR-III has the 'advantage' of a newly developed power load formula in a second power tube. Wow! Perhaps I'll get one too.
                funny but lots of people came to my uncle's garden with several antennas non of them succeeded.
                my uncle says these rods only find cavity and water .I also find my own water with rods and a old earthenware water pipe in my garden.
                all smiles to unbelievers.
                only swinging gun like rod find gold with blind test.
                respects
                  The PMR III* only costs $2,495…why not get one for each hand? Double your chances, double your fun!
                  *The PMR-III can be used to search for gold, silver, diamonds, paper money, lead, copper, mercury or any other metal or mineral.
                    Target Fixed
                    OK, now my target is 7 rolls of pre-1980 pennies, more than half wheat cents, rolls slightly less than full.....will bury tonight or tomorrow.....and will not start to test for two successive rains..... :o :confused:
                      I've just looked back over your previous postings on this subject, and now I'm not sure what you're planning to use to detect these coins. :confused:
                      Do you have an LRL, dowsing rod, or a proper detector? Or will it be a combination of the above?
                        testing
                        Q, I am going to test an older Anderson Universal Antenna Rod-a dowsing rod......going to give it a decent chance.....in the field...and will note any pertinent info....
