Hello all,
I've seen the following explanation from George Payne about ground effects in the loop of a metal detector:
A pure ground is a soil condition that reacts like it was pure ferrite -- in other words, a perfect magnetic condition where no electrical conduction (eddy currents) takes place. We can think of this as a soil that produces a signal in the detector with zero phase shift relative to the transmitted signal. This is considered our reference signal of zero phase to which all other signals can be referenced to. Of course, the only real life object that produces this type of signal is pure ferrite. So ferrite becomes our reference target and produces what we call a pure "X" reactive signal.
Real ground conditions do not behave like pure ferrite. When subjected to a detector's magnetic field, small currents begin to flow in the soil. This will cause the soil signal to be displaced slightly from that of pure ferrite. We call this difference a phase shift and define it to have an angle in degrees negative relative to pure ferrite. In addition, this phase shift produces a new signal in the detector which we call the "R" component signal. We can carry this analysis one step further. Using trigonometry, the ratio of the X signal to the R signal can be shown to be the actual measured phase of the ground.
All grounds have varying amounts of magnetic and conductive properties. Therefore, the ratio of the X (magnetic signal) and R (conductive signal) will vary from one location to another. However, the phase produced by this characteristic will always be negative relative to zero (the phase of pure ferrite).
From my experience, most grounds produce a phase that falls somewhere between zero (ferrite) and a -5 degrees. Some highly magnetic soils can have a phase that is quite low, but it can never be zero. Once the phase exceeds several degrees the ground characteristics begin to fall into an area where it becomes more saline. This doesn't mean that it's not magnetic. It's just that the R (conductive component) of the ground becomes stronger in relation to the magnetic portion. Thus, the phase becomes greater.
____________________________________
Fantastic. I´m sure George is a md Guru and I'm an idiot (it is not an irony), because I can't see what ground phase is named, is it the delay in the ground received signal with regard to ferrite received signal?, what does it happen with the amplitude of the signal?, is the phase the ratio of X to R? what really are R an X really? what is the influence of real and imaginary parts of the loop impedance? What is ground conductivity? Could any of you provide an explanation for idiots as I? Could be indicated with graphics and mathematical expresssions?
I am very sorry because there are a lot of questions before. I have a mathemathical and electronics background, but I am not able to undestand (see) the ground influence and perhaps the discrimination phenomenon. Could anybody give a clear (for me ) information?
Thank you
Frank
Thank you
Frank
