Hi, I am an almost graduated Electronic Engineer and I always loved metal detectors. Since I lately managed to have some spare time, I am experimenting with some circuits in order to make my own detector.
I am starting with an IB detector with resonant TX coil at 15kHz and I am making some experiments with various DD coils. Here's what I did so far:
1. TX coil: 55 turns, 0.35mm wire diameter. Coil diameter is 22cm, L = 1.38mH;
1a. Feedback coil: 7 turns 0.35wire diameter, placed right above the TX coil. I take form there the TX signal so that i do not interfere with the oscillator.
2. RX coil: 180 turns, 0.35mm wire diameter. Coil diameter is 22cm, L = 4.6mH. Shielded with alluminum foil connected to GND;
3. TX coil 2: 35 turns, 1mm wire diameter. Coil diameter is 22cm. L = 650uH;
As a transmitter i first used a TDA2030A based amplifier so that I could easily change frequency, but I soon moved to a colpitts oscillator (see schematic attached) and I managed to boost the signal at the coil up to 150V! just by using a DCDC boost converter and powering the oscillator at some 40V DC. Measured current in the TX coil was up to 1.8A. I am now powering my oscillator at 20VDC.
At first I used TXcoil1 and RXcoil and got some usefull resoults that at least told me I was in the right direction. I was able to detect a 2€ coin at 8cm and my phone at almost 20cm.
The problem is that each time I try the circuit, it always give me different resoults! There must be something I am missing or clearely doing in the wrong way. Here's a list of what I think is wrong:
a. Is the TX signal too strong? With a test coil put directly over the TX coil I am able to detect it's magnetic field to up to 2m distance.
b. The RX signal is impossible to cancel out. With a tuned capacitor in parallel to the RX coil all I can get is 200mVp minimum. The amplifier then boost this voltage but it is not sensitive at all.
c. When the RX signal is at its minimum the phase shift between it and the TX signal is 90°. Putting an object close causes a slightly increase of it's magnitude but a more noticeble (expecially in XY mode) phase shift.
d. Lowering the TX frequency down to 9kHz gives even more useless performaces.
e. TX coil 2 resonate with a much lower voltage, some 20Vpp (TX1 resonate at 60Vpp when oscillator is powered at 20V).
f. Shold I wound the coils in some specific way? (one CW, the other CCW? Should not make any difference).
g. FB signal is strong enough (3vpp) no need to amplify it.
h. Nothing else comes to my mind right now but I am sure that there is a lot more
Brief explenation of the circuit: The TX oscillator is brutally copied form the Tesoro Bandido II design, as well as the RX amplifier (I have tried several configuration but this one just works better). Both RX and FB signal are squared up by two comparators. The phase shift between the two is measured by the time in wich both comparator are concurrently on. The two mosfets in series just implement an AND gate. Said time have to be precisely mesured by a microcontroller. For now I am just woriking on the pahse shift, I think that I will make an envelope detector and sample the amplitude using the uC ADC.
I am making all sort of measures and comparisons to my design so that I will be able to understand wich factors determine this lack in sensitivity. I hope that you guys could give me some advices on how to proceed. I am diving in all forum posts and I am already learning a lot, so thank you all for that!
