If not you are able to suck up, exhale Use the syringe and of suitable thickness neddle. Warm with the soldering iron and exhale tin from everyone pin. It is possible to take IC out without any problems. I am applying this method for many years.
Mrand
Yo uso Mercurio... pongo un poco de mercurio en la punta del cautín derrito el estaño de cada terminal ligando estaño con mercurio... esta aleación queda semi-liquida y luego saco el IC sin dificultades...
Hay que limpiar bien luego de hacer esto...
Tapar la nariz y boca con algo pues los vapores de mercurio son tóxicos o usar extrator de aire.
Saludos
DIMINUTE
I use Mercury… I put a little mercury in the end of cautín I melt the tin of each terminal binding tin with mercury… this alloy is left and soon to coat the IC without difficulties semifluid… It is necessary to clean well after doing this… To cover the nose and mouth with something because the mercury steam are toxic or to use extrator of air. Greetings DIMINUTE
