The TX phase should not shift. Phase shift TX is a negative effect of temperature and soil on the inductance of the TX coil.
Stability of the VDI scale
Originally posted by JoyJo View Post...
Heat or cool the Tx circuit together with the capacitor from 0 to plus 35 ( in tabular form 0, +5, +10,+15 +20, +25)...and look at what will change (resistance, inductance, amplitude, etc.) if it changes. If the inductance of the Tx coil were changing, then you would have the circuit frequency "changing/floating", but it's not, right? Then what does the contour of the Tx have to do with it? Maybe it's something else? Generally...one of the ways...for thermo stabilization of the coil and capacitor...they use/select capacitors with different TKE, but(!) this is if it is required...
No. It's not just the cascade that's the problem. The question was fundamentally different: why does the VDI scale not shift in branded metal detectors during the entire period of operation. Or in another way: How do branded metal detectors work without ferrite tuning?
Sorry, I disagree. Based on the practice of making coils. But you can check for yourself. Take 1 block and make it...wind, etc. 2 coils with the same parameters in total(!). And put up a "ferrite". And you will see that the discrepancies will be at least 1-4 points/degrees. At the same time, keep in mind that you do it manually. And in factories, as you know, the winding of the same coils...automated/standardized, etc.
>Then how or by an algorithm can software compensation for the drift of the start point of the VDI scale >be provided?
"Ferrite is not a soil," do you remember such a phrase, etc.? This is on the one hand. On the other hand, make good sensor balance compensation.
