TM 808 White's
To generate 6.5 kHz you can use attiny85 and this program
HTML Code:#include <avr/io.h> #include <avr/interrupt.h> void comp_match() { DDRB |= (1 << PB0); // set PB0 as output TCCR0A = 0x00; TCCR0B = 0x00; TCCR0B |= (1 << CS00); // No prescaling TCCR0A |= (1 << WGM01); // Toggle mode and compare match mode OCR0A = 75; // Compare value can be calculated as frequency = Clock / OCR0A // A value of 75 leads to about 108,6 kHz at a clock rate of 8150000 Hz TCNT0 = 0; sei(); // Enabling global interrupt TIMSK |= (1 << OCIE0A); } ISR(TIMER0_COMPA_vect) { PORTB ^= (1 << PB0); //Toggling port PB0 } void setup() { comp_match(); }; void loop() { } /* The expected frequency can be calculated as freq = clock rate / compare value In this specific case the clock rate is around 8 150 000 Hz. (See frequency 81 kHz for compare value 100) Empirical data measured 2023-08-23 with a noname ATtiny 85 board compare value Frequency 1..37 -> 217.3 kHz 38 -> 211,5kHz 40 -> 201 kHz 50 -> 162 kHz 60 -> 135 kHz 70 -> 116,3 kHz 75 -> 108,6 kHz 76 -> 107,3 kHz 80 -> 102 kHz 100 -> 81,8 kHz 200 -> 41,1 kHz 255 -> 32,3 kHz */
Originally posted by berreizeta View Post
I have two questions.
1. What are the values of Tx, Rx capacitors
2. Can you put the yellow coil under the table on the floor while the Tx is on it?
What amplitude do you have on the that probe coil?
My coils are not final, they are just to test the circuit, they are not perfect.
I do the calculation of the capacitors/frequency with:
https://ekalk.eu/lc_es.html
With the coil on the ground at 80cm, barely 1V reaches the circuit, and the preamp MC33078 needs a minimum of 1.6V)
With the coil at 45cm, it reaches enough for the preamp to act, giving about 13.5V
If for testing you can use your yellow coil I can compare your transmitter with mine, for that I need to know also diameter of your coil and number of turns.
What is the value capacitors of the coils that you have ?
The last oscilloscope is telling that bias of the amplifier is incorrect, the pulses should be 50% duty cycle.
This arrangement allow you to check sensitivity (range ) of detector without additional electronics using just oscilloscope, for balancing move the coil back an forward.
