TM 808 White's
  • #76
    well the speech in the video is in English and that's what counts.
    • #77
      if you need in good deeper buy this KIT in a link you see here. do not waste your time on TM-808. this is my suggestion for you. you will get CLONE-AVR completed-tested PCB, LCD, PCB with knobs. you can put all in a box, your work will be only to do a coil for the deeper.
      http://reibert.info/forum/showthread...16#post1505116
      • #78
        hi ivconic
        what about for this quartz it's not found in my county,any idea to replace it by other?
Name:	Sans titre.JPG
        • #79
          Originally posted by aventurier View Post
          hi ivconic
          [ATTACH]13606[/ATTACH]
          For a long time, I cannot see ivconic at this forum ,
          I am hoping comeback .
          Base on theory , I think you can use instead , 32 kHz crystal .
          You can found it form watch !!
          • #80
            yes i found it in one of watch thx
            • #81
              tm808 deffective
              sir i have also a problem on my tm808.i buy new battery but cannot goto the yellow mark,its only 2 on the meter with continued hamming.What parts are deffective?pls.help me
              • #82
                your buy alkalain battry?
                • #83
                  YES SIR I BUY ALKALIN BATTERY BUT IT COULD NOT..AND ALSO MY TM808 CANNOT EVEN DETTECT ANY MORE..I NEED YOUR HELP SIR....THANKS VERY MUCH FOR YOUR REPLY
                  • #84
                    HELLO. your tm808 adust IC regulator please call to the whites factory.and send for a repair in to the whites the tm 808 .2 year warranty.
                    • #85
                      AH OKEY SIR THANKS,I CANNOT SENT TO THEM RIGHT NOW COZ WE HAVE SO MANY SIGHTINGS HERE IN SOUTHERN PARTS OF THE PHILIPPINES WERE THE LOST YAMA****A TREASURE ARE BURIED,BY THE WAY SIR DO YOU HAVE AN IDEA WHAT IS THE GOOD UNDER GROUND APPARATUS THAT CAN DETECT UP TO 100 FEET DEPTH...AND ALSO THE GOOD LONG RANGE LOCATOR APPARATUS?
                      • #86
                        hello sir the best trasure hunter whites tm808 because very perfect and profitional but the all long rang detector (lrl) it is a toy not found the trasure. i working all lrl no good just a toy but i working tm 808 and found the rilck and...i work okm rover deluxe rover cii and.. okm just the toy i work the runebut(accrocate locators) better tha as okm.i buy and work any metal detector and lrl the best metal detector whites tm808+LRLMAN(arcjeo) tm808 can found the very old metal(trasure)deep serching 11 meter object 1m.50cm(+LRLMAN) but tm 808 new object metal 2m.2m just found the 6 meter but the very very old object metal found the 11 meter
                        • #87
                          your tm808 it is a new (3 volume or 4 volume)the tm 808 3 volume new and smd .but tm808 old 4 volume not smd beacuse esaly repair. are you Renovation?can you found the all ic tm808 in to the country?until help you for a repair.
                          • #88
                            hello
                            i help you for a repairtm808
                            • #89
                              tm808
                              sir pourang thanks for your help,i replaced all ics that you told for my tm808 cave mode and nows its okey..do you have any idea on how to improved this tm808 cave mode to dettect old treasure up to 15 meter?...and also please help to the correct ussage on this project tm808?
                              • #90
                                tm808
                                hello the wire core transmit (coil) 82 trun for a tuning tm808.but not estabile.the system.and very very hard oprating system .but serch deeping up 10 meter detect object.but the old version tm (tm800) very good tuning for a deeping search.but tm808 no good ida for a tuning
