Originally posted by Atul Asthana
View Post
No I have not made it ... but Ivica might like it because it uses ESP32
IMHO Noise specs are not relevant till the noise is specified with respect to bandwidth ... and also if the noise is synchronous with the wanted signal elements. Generally speaking non synchronous wideband noise has little effect on the wanted synchronous components. - in oversampling schemes .. noise at the input actually helps.
A wideband software defined radio has no preselectors at its wideband input but can resolve less than 1 Hertz of bandwith signal in an input bandwidth spanning 10s of Mhz. Lock in amplifiers are an extreme example of this and can recover signals below the wideband noise floor at the input ... in fact the lock in amp will recover the phase and amplitude of a signal well below the input noise floor ( if the TX phase and frequency is known --- CRITICAL POINT 1 ). If the signal is very weak then you just integrate the phase and amplitude for longer. Sampling ADCs use a modulator to do the sampling .... the sampling frequency adds convolution noise to the samples .. almost impossible ( cant be filtered ) to remove once its in the data so care in choice of sampling frequency for high performance systems..CRITICAL POINT 2. The sweep speed of the coil determines the target detection passband ( for most handheld detectors this will be from DC to 10 hertz for example ) this is the demodulation target bandwith CRITICAL POINT 3. Has to be DC so phase and amplitude polarity can be resolved without reference to an artificial tracking level... most detectors cant do this because integrator baselines drift all over the place. ( hence motion and non motion ).
moodz
