I was considering whether we could explore using 2–3 different TX frequencies interleaved in adjecent time slots, frrquencies being on either side of the main TX frequency.
Our coils have a low Q and perform similarly good enough at 5800 Hz and 6200 Hz. With an op-amp filter bandwidth of ±400 Hz and precise control over the TX frequency, we can operate within these limits. Additionally, the signal processing in each TX slot is independent of the preceding or succeeding slots.
This allows us to transmit and process different frequencies in separate time slots: Slot 1 at 5800 Hz, Slot 2 at 6000 Hz, and Slot 3 at 6200 Hz. The received signals from these slots can be analyzed using the Goertzel algorithm to extract amplitude and phase data for each frequency.
To effectively process and display this multi-frequency data, we’ll need a new technique to consolidate these results into meaningful information for the user. Increasing the number of slots to 512 and reducing the sine wave cycles per slot from 16 to 8 may help accommodate the additional data.
I’m curious to know the advantages this multi-frequency approach might offer and what strategies could be employed to integrate and optimize these results for improved performance in the metal detector. Could this enhance target discrimination, depth estimation, or reduce ground noise interference?
please opine.
please opine.
