Hello all
I’m brand new to the forum and I’ve already found some valuable info on the site. I have a Coinmaster 6/DB Detector. The last time I had it out was ≈ 15 yrs ago and it worked fine; it has been stored in a garage ever since. I have found the schematic on this site…but I wonder if anyone has any detailed troubleshooting tips/measurements.
The only thing that seems to work is the battery check for 9V & 12V which registers good on the meter. When I go to perform the “G.E.B. Tuning Indoors” procedure per the manual, I get nothing after the battery check, no tone at all, despite adjusting the tuning & volume. I have pulled the knobs and used Deoxit on the 2 switches and WD40 on the 4 pots. Everything is a lot smoother except the Discriminate Adjust potentiometer; it is really hard to adjust and the inside case nut was not right, so the shaft barely sticks out. I’m going to de-solder that potentiometer and see if I can free it up or replace it. I would like to test the detector loop, it feeds the case with a 5-pin connector. Can anybody provide the correct values at this connector or any other troubleshooting tips?
The circuit board looks clean, the meter, speaker and battery pack connections are all soldered secure. Thanks in advance for any information that might get this classic to work again.
