7660 operating frequency
  • 7660 operating frequency
    Hi all,
    I want to increase the ICL7660S operating frequency up to 20 MHz by using an external clocking.
    Is it possible? If so, How?
    I think it's possible to use the hi-freq (internal 120Khz) version from Microchip, TC7660H:
    see the datasheet at the following link
    ww1.microchip.com/downloads/en/devicedoc/21466a.pdf
    that says:
    Changing the TC7660H Oscillator Frequency
    It may be desirable in some applications (due to noise or
    other considerations) to increase or decease the oscillator
    frequency. This can be achieved by overdriving the oscillator
    from an external clock, as shown in Figure 6. In order to
    prevent possible device latch-up, a 1kΩ resistor must be
    used in series with the clock output. In a situation where the
    designer has generated the external clock frequency using
    TTL logic, the addition of a 10kΩ pull-up resistor to V+ supply
    is required. Note that the pump frequency with external
    clocking, as with internal clocking, will be 1/2 of the clock
    frequency. Output transitions occur on the positive-going
    edge of the clock.
    So e.g. ttl clocks (max 20mhz) or other faster clocks may be used but efficiency and consumptions considerations should be considered before any attempt.
    Best regards,
      Thank you Max,
      But I don't reach to that version of 7660...
        I doubt you can run it up to 20MHz. The data sheet only specs performance up to 10kHz, and efficiency is beginning to roll off.
