If any body has Lorenz LPX2, I need close pics for internal coil jack wiring with two risistors. I played with the wires and do not know how to reconnect them.
Based on wire color only I can't help you. But if you have pictures of the inside of the detector (component side/ solder side) and the picture of the coil connector socket (that is conected to the PCB) and your coil connetor the chances are much higher that someone can help you to fix it.
