Originally posted by zzy
View Post
the problem is that good geb setting is difficault to achieve.
If you modify resonance at rx coil you could experience problems cause there's also phase shift you introduce this way.
I suggest you check your frequency then try to reject small ferrite stuff e.g. little rods or toroids but not totally... just it must give some cracks when very near to coil... this is enough to have geb working and save sensitivity.
Require a bit of patience... I know.
On mine I reject almost totally (small cracks) the ferrite things and have really good depth using Ivconic's coil design.
Kind regards,
