TESORO GOLDEN SABRE
  • TGS - almost ready to run in field
    URRA!
    FINALLY!
    My TGS is good.
    I am studying the TGS very hardly.Than I decided to build a omega coil. After I nulled the coil with scope and adj. GEB control...bit to bit...until to take almost total silence. With a bit less sens. control...Success...total silent.
    Freq. 14.7KHz
    Small gold ring - 30 cm in air
    nickel coin (2.3cm) - 28cm
    Bimetal coin (+ - 3.0cm) 33 cm
    Alluminium itens - UAU!
    Omega circle (TX = 25cm OD) - 26.3 ohms - 5,49mH
    Circle (RX = 13cm OD) - 20 ohms - 6.7mH
    Wire - 0.25mm diam.
    Small contra circle - 10cm. OD.
    Discrimination OK
    Strong audio
    No improvements at PCB
    Now I intend to build a new omega coil with a more large tickness wire for omega circle coil only.Later I'd post the results.
    IVCONIC was right omega coil is superb.
    DIRCEU
    • Hi dirceu,
      congratulations,
      And thanks for infos!
      Good luck using it
      regards,
      Fred.
      • Originally posted by DIRCEU View Post
        URRA!
        FINALLY!
        My TGS is good.
        Freq. 14.7KHz
        Wire - 0.25mm diam.
        Discrimination OK
        Strong audio
        DIRCEU
        Nice! Well done.
        • Good job Dirceu!
          Cheers!
            URRA!
            FINALLY!
            My TGS is good.
            Freq. 14.7KHz
            Wire - 0.25mm diam.
            Discrimination OK
            Strong audio
            DIRCEU
            Well done ... very interesting.
            But you missed one important detail - how many turns did you use on the TX and RX coils?
            • Hi Ivconic how are you.Grt Nakky
              • Hi Nakky and other friends. Very exhausted from gall bladder removal. Most of time i am in bed. Do have strenght only for 10 minutes per day to sit and check new posts here. Splendid jod done here and on RH thread. Looking forward to recover and start building RH. Cheers!
                  Hi Ivconic,
                  I hope you'll recover full health soon. I know the feeling of wanna doing something and cannot move for a while...so I understand you very well.
                  I will enjoy your partecipation in th RH thread... but no problem, first you have to stay fine again.
                  Best wishes,
                  • Hi ivconic
                    Don’t worry, my friend removal gall bladder and very well now .only doctor
                    Said him, don’t eating egg and more eating sugar . anyway I hope you'll recover
                    full health as soon as.
                    best wishes.
                    Aft_72005
                      FRED; MAX; IVCONIC... Thanks!
                      To QIAOZHI.
                      Oh! yes. I forgot to explain this.
                      Don't know.
                      I wounded the coil fix on the resistance(+_20R) with 0.25mm wire but I don't considered the contra circle(10cm diam.) Thus the resistance up over 26R with only 5.49mH. This way I changed TX by RX and work very good.
                      I think the solution for it is to wound a coil with a bit more large wire (0.30mm diam.)...may be close the values requireds OK?
                      • Hi Ivconic,
                        Hi Dirceu,
                        Did you take your coil inductances separately or when they are together , in finished configuration?
                        Ivconic, get well soon! there is plenty of experiments to do
                        Best regards,
                        Fred.
                        • Hi! IVCONIC
                          Gall bladder surgery is very common today. But fat foods now...NO NO
                          I trust you'll soon be better and we hold him in high regards.
                          DIRCEU
                            Hi Ivconic,
                            Hi Dirceu,
                            Best regards,
                            Fred.
                            Hi! FRED
                            I measured separately.
                            DIRCEU.
                            • Many thanks friends!
                              • HEY İVCONİK
                                We are planning to transfer you our Turkish Detector team please be healty.
                                We are planning firstly win europian footbol sampionship and later on dedektors by your
                                support .
                                Erol
