TESORO GOLDEN SABRE
    Thanks for reference looks good. Looks like they put a sync pulse into the capacitor timing input -- hey, if it works... This chip needs external coil "buck-boost" type looks like, 300uH not to big I guess, but other 7660 just need capacitors. Usually type with coil higher efficiency though I think.
    Another design possibility if you're feeling creative instead of sync pulse is to let the voltage regulator free run and use it's oscillator to drive TX coil; an idea I'd like to try sometime.
    Cheers!
    free run mode is no good: intermodulation between md timing signals and analog with converter clock.
    Kind regards,
      Kind regards,
      I meant use voltage reg oscillator to drive TX coil, everything in sync!
      Glad you are back, hope all is well.
        I'm back just for a while... have to think something else... but problems are still there.
        I think it's a good idea sync converter with tx stage.
        Kind regards,
          Kind regards,
          Hi Max,
          Welcome back,
          Forum has much less activity on tecnhical matters without your comments ...
          Fred.
            Hi Max,
            Welcome back,
            Fred.
            thanks, you know... I cannot think about problems all the time... so I relax a bit here looking for interesting stuff (actually distracting myself from the troubles and bad things I see - unfortunately - everyday).
            It's kind of brainwash, needed to go ahead these days... so will be not only about technical posts... maybe some sarcasm here and there...
            Like Dr. House maybe ?
            Worse things around...that I see, enormous troubles...as example... yesterday I saw a young, beautiful woman die... not a good thing to see, belive me...that's why I cannot sleep much these days.
            Sure... I know this is OFF-TOPIC here so I will not write more about.
            Kind regards,
            • Hi,
              Ivica.
              How are you?
              I have solved my problemes with TGSL1265.Now its almost complete.Bad capacitators!Now I am changing all of them.
              Can you please tell me where I have to attach this small PCB with the monostable?To GND or -8V?
              Its a lot quieter than TGS.
              I like it.I use the old setup with 2X2n2907 and 2X2N2222 all metal.And now just for tests TL081 insteed of LM308.I dont have a pair now.I am waiting for one soon.
                Kind regards,
                We wish you better days ahead...
                • TESORO GOLDEN SABRE
                  Kind regards,
                  Glad to hear your still around Max , I am working away from home for several weeks , Its terrible to be in an area with no cell phone signal and no internet!!! I will be back on everyday , sometime around or just after Thanksgiving . A little bit early , but , Happy Thanksgiving To everyone on this Geotech Forum !!! Take Care everyone !!!! ..........Eugene52 / formerly Amtech2005/stalni-clan of Ivconics Hobi-Detektori
                  • Hi Eugene,
                    So you could find a place without net and cellphones? this still exist on Earth ?!! Cool !
                    Good luck !,
                    Fred.
                    • Hi Eugene,
                      Good luck !,
                      Fred.
                      Yes, he used the old map from Esteban... and your Google air photo....???
                      I think he found Treasere Island.....
                      Ap
                      • Hi,
                        Can this tesoro be made with diode indication for detection?
                        I mean when there is a target the light on.This might be usefull.
                        • Originally posted by ApBerg View Post
                          Ap
                          Hi Ap,
                          I hope so!! after all he was the one referring giving 10%
                          Good luck,
                          Fred.
                            Hi Eugene,
                            Good luck !,
                            Fred.
                            Ap
                            Hello Everyone , There is strong signal in town , but where I am working is
                            Only 1 bar of wep / wpa encrypted internet signal 802g , Labeled as "2wire" ................. I am now eligible to be on that famous TV show called "Worlds Most dirtiest & Crummiest remotely Located "ISOLATED" Job in the world" Yup , if its not there , I will find it...............Take care everyone.....................Eugene52
                            • Hi
                              Ivica.
                              I now that you have a lot of work and also you are on other project but Please help here.
                              I have made a progress with my TGSL 1265.Buy changing some caps.But still havent recived my pair of LM308 and just for tests 081 but this make a diferance as you now.So I get a prety good responce and loud sound but I have proceeded to change caps and now the sound is broken.Damn.From a begining again.
                              I will make a picture with the TRs voltages so you can help.I suspect something there.
                              Also can you tell me where to conect the - point from monostable?To -8V or GND?
                              I have tryed TLC271 insteed of LM308 but no good.
                              • Golden Sabre on E-Bay
                                http://cgi.ebay.com/ws/eBayISAPI.dll...m=290272107600
                                Only about 8 hours Left!
