TESORO GOLDEN SABRE
  • TESORO GOLDEN SABRE
    Originally posted by tiktak View Post
    Eugen 52.
    I now that you make this for fun but its pointless.
    You see all is good and working.Just some tunungs needed to achive the best performance according to components used.I wanna tell you that my 2N2222 have the exacly oposite pins from what you showed!So no point.Everything is ok.
    Everyone have to wach for TRs pins and all is OK.
    But this must be solved for each situation individualy.
    So dont worry.We have it all already.
    Major THANKS to Ivconic who make this posible!
    Hello tiktak , You are correct !! I should of posted this in a small ZIP-FOLDER . I want to make this PCB on 2 separate circuit boards , keeping battery / supply and Audio on one circuit board and the RX , TX on the other . I am trying express PCB and express schem. ........I will post the results later in small zip-files . Have a Great new Year tiktak !!....Comments are always welcome !!......Eugene52
    • Originally posted by Eugene52 View Post
      Hello SimonBaker , Have you tried Express-schem. and express-Pcb . ??? Is it working Good ?? Ivconics sprint looks Great , I do want to try different pcb software , any suggestions are welcome , Regards................Eugene
      Yes, I have used ExpressSCH and ExpressPCB to draw schematic and PCB, and link schematic to PCB to help make correct PCB.
      I like the software pretty well. ExpressSCH has nice validate feature to find unconnected components and duplicate names, very useful.
      ExpressPCB is basic, but if had a few more features, would be killer. I have put in requests, but don't know if they care or not. Support is very good, Heidi answers your questions. Their help files are not searchable though, seems a little stupid -- maybe they are afraid someone will steal them?????
      The capacitors in ExpressPCB are just drawn as boxes, but you can add the symbol yourself and make a custom component easily. The library components' pads seemed too thin for my taste, so I made custom components with thicker pads, trying to match pads on a Sprint Layout PCB.
      A good feature is that if you link to your schematic, when you click on a component pin, you can highlight all the other pins on your PCB it is connected to. You can almost draw your PCB without looking at schematic.
      Also, if you move component, the traces will stretch and go with it.
      Some features are needed in ExpressPCB:
      1. Validation - ExpressPCB needs a general validation function to warn if components are missing connections, or if some components on schematics are not on PCB. Actually, it will warn you when you touch a pin if some other pins from schematic is missing, so you find out missing connections when drawing traces.
      2. Image layer -- ExpressPCB needs a phantom "layer" where you can import an image of an existing PCB so you can draw traces exactly like it.
      3. Neither program can export a netlist. ExpressPCB can import a netlist I think.
      4. Components cannot be rotated to diagonal, not too important.
      5. Other minor shortcomings -- more zoom settings would be nice. It would be nice if all components from linked schematics could be dumped onto board, or at least selected from a list. It would be nice to have extra silkscreen layers that can be turned on or off during printing, so you can choose how much labeling, what language, etc.
      6. Some people complained of printing limitations, I do not know what they mean. I think Sprint Layout has much more flexible and powerful printing.
      7. Basically ExpressPCB hopes you will send them your files to order PCB from them, so they will never be super-motivated to help the do-it-yourselfer.
        Why you need to be careful with TO-92 pinouts:
        http://www.armory.com/~rstevew/Publi...anspinouts.htm
        As Ivconic says, you need to check on a case by case basis. I've been caught out by this before
        Yes, you have to be careful on schematic which pin number corresponds to base, collector, etc.
        ExpressPCB defines pin number locations just for the TO-92 package shape, doesn't care the function of pin. What I don't know is if this pin-numbering is universal, or other programs or diagrams number them differently. I will be posting a version of Ivconic's final schematic with pin numbers for the transistors based on ExpressPCB TO-92 package and J107, 2n2907, 2n2222 Fairchild TO-92 components. I agree it is up to the circuit builder to verify the actual pins of their own components.
        • If you want a free PCB layout package, and you don't care about the schematic, you could try Pad2Pad -> www.pad2pad.com
          It's simple to use, and even has an autorouter, DRC and BOM.
          • PLEASE, is it possible someone to share the Gerber files?
            Thanks a lot!!
              Thanks a lot!!
              Hello Zpe , which Gerber files ?? For the Tesoro Golden Sabre or Something else ? I am going to Start a new Thread , I will call "Easiest PCB and Schematic software" It will help me , because I am getting ready to order a bunch of PCB "circuit boards" . I will doing all the preliminary work myself and then place an order . Anyway this is the Golden Sabre thread , so we want to keep everyone happy and post the pcb and schematic software stuff separate !!!!!..........Regards...........Eugene52
              • Hi Eugene, I need of gerber for Tesoro Golden Sabre. Thank you in advance.
                I would like to order a PCB boards for myself.
                • Hi
                  Where are you from ZPE?
                  • Hi folks, I just would like someone to share a Gerber files for Tesoro Golden Sabre. For me is easier and cheaper to order a couple of boards sending a gerber files to a company.
                    • Originally posted by zpe View Post
                      Someone with Sprint-Layout software should be able to export a Gerber file for you -- or you can get Sprint-Layout youself and do it.
                      You might want to check with your PCB maker also to see if they accept the Sprint-Layout native ".lay" files, some do.
                      • Tesoro GOLDEN SABRE
                        Thanks a lot!!
                        Hello Zpe , Go ahead and see if this works !! The latest TGSL !! I converted to Gerber from Sprint 5.0 this morning . It exported 2 files , let me know if this helps you .............Regards.......Eugene52
                        • Thanks a lot Eugene!!! I am sure that it would works.
                          • R6 22k?
                            Another nitpicky question for Ivconic:
                            In last GSaberLight.sch file, R6 (to base of TR1) is 22k instead of 24k like other schematics.
                            Is that because it works better, or just more convenient and available?
                            Also: Do you have a PCB ".lay" file for the full TGS with notch?
                            Thanks,
                            • TESORO GOLDEN SABRE LIGHT
                              Thanks,
                              Hello again SB , HERE is From page 20 of this Thread we are on , I think this is Full Version ? If not let me know !!!...........Regards............Eugene52
                                Thank you very much, that probably will be good for me.
                                I have an idea I would like to try later where I will substitute a different purpose for the notch channels.
                                Cheers,
