sorry, pin+ C4 is +6.02 V, pin- C4 230mv,fixed audio is playing.
TESORO GOLDEN SABRE
Ivconic or Simonbaker
can you re-post a schematic of a working TGS that you've built along with the PCB, parts and layouts? Following these, sometimes I am lost as to what is the latest, and best schematics. I would love to make one, but finding the right schemas can be very tricky now. Either that, or can you email me something that I can work on?
can there also be a section where there's complete postings of schematics with PCB's and lists only that the moderators can only post to, so that we, the typical users, can find complete (working) details?
Thanks,
Milton
[email protected]
Thanks,
Milton
[email protected]
It is tough to weed through all the information and find a clear "kit" instructions.
This is the best there is, compiled by Qiaozhi, for a popular version of the TGSL:
http://www.geotech1.com/forums/showthread.php?t=15710
I still find it a challenge to make a very good device. It seems the hardest part is making a very good coil that gives top performance. But it should be fairly straight forward to make something that works at least moderately well. It seems to require some dedication and enjoyment in building many models to finally make one that is great, although some people seem to have good luck on first try.
Part of the fun is troubleshooting if your MD doesn't work first time you turn it on. A dual trace oscilloscope is really needed to see what you are doing.
Let us know how it goes.
Hi guys, this is location for LAYOUTView 5.0...
http://uploading.com/files/ab8e8765/viewlayout50.rar/
Hello,
Recently I have finish TGSL last one.I wanned to test each stage but after oscillator were in a hurry and solder all components respecting the article.
My problem is:when switch on there is detection and disc.But very poor sens only few cm.And when switch allm mode no detection at all!!!Damn I payed attention to each detail.Check several times for error-cant find.
So maybe bad component?My problem is that I solder all ICs directly on PCB.Except 2 X LM308/they have sockets/.
So can someone tell me where to search?
First suspect this mode switch.But test it and it looks ok.
When I took off LM308 that is near 1000m cap.,device have detection in both modes but no disc any more.
Now that no one can solve my problem from distance.Just tired to search for mistake.
Thanks but nope.Cable is ok.Coil is not perfect but fine.
There should be something mistaken.
IC voltages are:
U101
pin1 0,27;pin2 0,24;pin3 0,00;pin4 -6,47;pin5 0,00;pin6 0,00;pin7 0,00;pin8 8,14
U102
pin1 -3,44;pin2 0,09;pin3 0,00;pin4 -6,47;pin5 0,00;pin6 0,00;pin7 -3,33;pin8 8,14
U103
pin1,2,3 0,00;pin4 -6,47;pin5,6,7;pin8 8,14
U105
pin1 7,48;pin2,3 0,00;pin4 -6,47;pin5,6 0,00;pin7 8,14;pin8 0,14
U106
pin1 -6,47;pin2,3 0,00;pin4 -6,47;pin5,6 0,00;pin7 -6,47;pin8 8,14
U104
pin1 -6,33;pin2,3 0,00;pin4 -6,47;pin5 -6,33;pin6 0,00;pin7 8,14;pin8 0,27
Voltages are 8,14 and -6,36 at begining.And I can see small change in - in RX stage -6,47
This is with one already sealed coil.There should be some mistake because no ALLM mode at all.
Originally posted by Ultimate_Haze View PostThanks but nope.Cable is ok.Coil is not perfect but fine.
IC voltages are:
U101
U102
U103
U105
U106
U104
Also try other coil, see if same.
Originally posted by Ultimate_Haze View PostHi,
Simonbaker.
Its same with 3 diferant coil.
Thats why I think its further in the chain.
I am prepering pictures now.But which outputs A or B?
It might be further in chain, but still should check these front end outputs first.
U103
Check that turning disc pot changes the voltage at pin 3, and turning GB pot changes voltage at pin 5. This assumes you have some kind of null signal at U101 pin 7, which I think you must if you get any detection at all, even though you measure zero (DC volts?).
Simonbaker.
So I try with another coil/DD22-TX=5,84mH;RX=6,2mH/.
Voltages are U103 pin3 -0,06;pin5 0,00.
All measurments were taken in 20Vrange DC volts.Disc mode
Turning disc pot change U103pin3 value.It starts from -0,06 and in the end shows -0,00.Turning GB trimer change U103 pin5 value also.Starts from 0,00 and at the end show -0,04.
But still detects 2cm nikel coin from only few cms.And no ALLM mode.No sound at all.Not even beep.
Have a technical problem with the pic-s.Will hand draw the diagrams and post them tommorow.
