TESORO GOLDEN SABRE
    resistance=18,5 for both!
    I think this should be enough!
    But.....
    think could be ok. Now null, then test.
    Kind regards,
    • hi
      Max!
      I null and leave between 0 and 1 mv because the 0 zone is too wide,but bad results! Try to turn conections,with shielding,without shielding!
      My multimeter is now better,but.....not good enough!
      The best point I can reach is around 30 cm for very large coin,but its like "pip" not repeated when goes back!
      I try even changing shape,but......poor!
      Please advice.
      I null with 15n cap!Should I try other?I have 1J;22p;473?/I dont now what is this?10n;100p????
      • 566
        Huh! I am trying to find best solution for audio....Still no miracles!
        LM(NE)566 is VCO, how about involving it in TGS..? Any ideas?
        One friend send me very interesting link:
        http://www.hq-elektronic.eu/index.html#sabre
        It is to complicated for already made TGS...but as stand alone project is very interesting! I am planing to make it later, maybe in winter...
        Now i want to mod TGS with as simple as possible (yet functional) audio...
        LM566 is subject....I'll see.
        I could use that audio part from "Beachcomber vlf90" but different voltages are bugging me...? Can it be modified to work on simple power supply,just 12v - non symetrical....I do not want to involve op-amp with virtual ground or simillar...
        Huh!
        I havent read all previous posts...I'll read those later.If some questions sorry cose i didnt answered....
        Best regards!
        • Hi
          Ivconik.
          What audiomodification you are using on your GS?
          How mich depth do you acive for larger coins?
          You told that its 40cm for 1cm coin!!!
          What about 1,5-2cm coin?
          How you null please explain?
          Did you start GS in allmetal mode and swinging coin search for greatest depth?Or I havent understand you right?!?!
          I have made coil 28cm according to your patern,but cant get the same performance!?!?!
          My wire were for 115 TX and 115 TX turns!Now I am runout of wire!
          But resistance is 18,5 for both!It should be enough!
          But dont work the same way!
          • ivconic
            Can't we use magnums audio?
            Just an Idea?
              Nulling already explained many times. There are several ways to null coils.
              Serac best for you and your conditions. BTW, best would be using scope and func.generator.I busted my scope long time ago. These days, mostly using my previous experiences I null coils without mich of instruments.ALready established proper method, so it is subjective. For you is best to obey Max's hints about nulling.
              Depth..? Depends of a coil. I made over 10 coils for TGS and all different with different depths...Last one can detect 1cm nickel coin at 27cm, but BURRIED IN THE GROUND, which is best result so far. Better than Minelab Sovereign GT! But i had to do so much to gain that result...Do not expect to beat it soon...
              Of course depth is dependable of many conditions, not only on detector and coil. Moisture,soil compounds,mineralization......
              I think you do not need to think to much on centimeters as long as your detector is working steady and can detect same coin at 20-22 cm in the ground - burried of course...More imortant is stabillity and discrimination than depth, trust me.
              I'll take a look on that audio and see...
              Right now i am interested mostly on LM566 or any other simple solution...
              Regards!
              • Huh!
                No, when i report my results, i always mean on detector switched in DISC mode and DISC pot. at "1"....I never tested TGS in ALL metal mode cose possible interferences and fake signals...
                • Yes!
                  Yes! I've got it!!!
                  It will work like hell with LM566! I am sure!
                  I am preparing new schematic.Will be ready tomorrow or day after, than i'll post it here...
                  Now TGS Light will have sound just as i always wanted.
                  It will be small,compact, so few components - but hell of detector!
                  I'll be back....
                  For those who cant wait, go and see Sascho Pulse IB Discriminator...
                  • These days, mostly using my previous experiences I null coils without mich of instruments.ALready established proper method, so it is subjective. For you is best to obey Max's hints about nulling.
                    Ivconic, because you're professional.
                    What??? Is this a bad joke???
                    • Originally posted by Nihil Roma Maius View Post
                      Hi Nihil,
                      Oh yeah,
                      YOUR METAL DETECTOR CAN DETECT A COIN ON SURFACE SOIL FROM METERS AWAY.
                      You're the master (of CLOWNS).
                      Kind regards,
                      • Wrong place
                        Please don't choke us any more. This isn't place for you. Go on remote sensing and discuss with your friends.Thank you!
                        • Shake hands!
                          Would be the best thing if you (Nihil) and Max shake hands and stop with this. No reason for that. I have very good friend (you all know him) who was pain in the *** here very often...Hardly managed to persuade him to stop....
                          If RObert could...why cant you?
                          Very BEST regards to both of you!
                          Thanks in advance!
                            Thanks in advance!
                            Hi ivconic,
                            yes i know. You are right.
                            No reason of continuos bugging here ! Even if often is funny task with people like that...
                            I've offered Nihil stopping the "BS war" here
                            cause I don't want push him too much... etc
                            But he's blind and have no patents!
                            He said I've discovered tantalium caps right now... that I can't null well coils that I made mistakes on my PCBs, you see his latest post above.
                            So he's trying to discredit me here and provoking my reactions.
                            What I have to do ?
                            I'll continue responding to his posts using a bit of irony... I'm sure that he could detect the level of BS we reached (25 meters) here with his metal detector from SA, but maybe don't care cause, at the end, it's just another nickname of same people.
                            So also if banned from here he'll continue keeping the business on with other nicknames... and raising some more piles.
                            At the end his scope is provoking me like with RObert... hope that I'll swap irony and sarcasm with wrongs, offenses and personal insults... to gain my ban !
                            But I'm very controlled person, don't fall into his traps apart some comics.
                            Old games, old players... as I've said.
                            No problems for me. (even if banned )
                            Kind regards,
                            BTW:
                            FOR NIHIL:
                            WHERE ARE YOUR PATENTS ? WHERE ARE PHOTO OF DEVICE ? WHERE ARE DEFINITIONS AND REFS FOR IT ? WHAT'S MODEL / BRAND ?
                            YOU REMAIN THE MASTER OF CLOWNS
                            • Hi, i m afraid to said this but my TGS is overrating my new ace 250. I know that ace 250 is a bigginers machine, but i did´t new that until i compared with TGS. Yesterday i went to the same park that my ace hit a few weeks ago and now i found more coins on the same place with my TGS. Of course this coins where detected deeper than my ace did.
                              What can i said...excellent machine. I can wait to see how it will perform after i finish and assembled my 22 cms coil.
                              The only think i noted is that i need to regulate GB, cause in some ground the detectors sounds intermitent and in some other fields does not.
                              Thanks guys
                              Best regards
                              Nelson
                              Hi Nelson,
                              congratulations: I'm happy cause your detector is working better now.
                              Yes, the TL081 would be Ok, also in analog crossref tables is indicated as direct LM308 replacement.
                              Also other parts are OK.
                              Kind regards,
                              • Hi
                                Nelson.What is the depth you have reached?For 1cm coin?
                                With wich coil did you test?
                                I still have some difficulties with making this work well!
