TESORO GOLDEN SABRE
Originally posted by mostafalesnar91 View PostIvconic is not here
That's old post.
And nothing is wrong there.
I would write the same today.
Today i have good dual channel oscilloscope.
But in the past there were periods when i didn't have one, bad or good.
So i used multimeter to balance the coils.
Some people disagree with my methods. Alright.
What i used back than; was to get original coil and perform the same method of measurements, write down what i measured, keep those records as reminder or reference.
When making new coil; i need just to replicate what i have in my records, simple as that.
That's why my method was successful to me. My coils were correct.
But if you don't have original coil; you can monitor RX signal after the first opamp and try to achieve lowest output during the balancing.
Any method you find on forum is good enough. Anything works.
Of course i would agree; using oscilloscope is the most "regular" way.
Originally posted by ivconic View PostI am here on forum, only i don't follow some old topics no more.
That's old post.
Tesoro is not min output, rather, min out with 21.23 degrees phase shift with respect to TX.
You lost your way.
Either you are totally deadly drunk... either you using some heavy drugs... either you are in terminal phase of some incurable illness.
Now you became a forum spammer too?
Illiterate of course, just look your words and sentences!?
Qiaozhi will have lot of work to do here...
How many Tesoros did you make so far?
You mindless baboon! Mixing pears and apples.
0 volts residual voltage at Tesoro coil is 22 degrees shifted phase related to TX.
Majority of diyers here will not have tools and equipment to compare and measure the phase, so the residual voltage is everything they can rely on.
Instead of Copy&Paste somebody else's posts; you better stop with heavy drinking and try to make at least one simple metal detector.
How many Tesoro detectors did you make so far? Poor creature.
super drooper megadeath high technology ground penetrator radar.
https://www.youtube.com/watch?v=Hblt...58IqgGN4AaABAg
My apologies to you.
I've been given a notice to move, you know, I'm a tenant.
Never the less, my name is David Christopher Nisbeth.
Thanks you guys, I love all of you.
Look in the trees, I smell humans.....General Ucko, planet of the apes.
Originally posted by kt315 View PostEither you are totally deadly drunk... either you using some heavy drugs... either you are in terminal phase of some incurable illness.
Dave mustain. Heck of a guy. With Marty Friedman, rust in piece.
