****, yes! Here it is 4.9 euros!!! TL081 is 40cents....
I am worrying about my smd pcbs...I put TL082 in those to replace 2 LM308.....So you see, on ordinary pcb i can put LM308 even is expensive, but on smd? What should i put? LF353?
It will "eat" me few days more to find solution!!! ****!
Regards!
Hi Ivconic,
think that a good smd could be LT1012... as porkluvr suggested, but never tested it so I don't know for sure. Problem is finding it cause LT devices are few used as spare devices, so could be hard to find them e.g. in shops.
Colpitts formula for the TX frequency (signal at TX coil).
LC circuit formula for RX resonance, if you need to know it I mean.
When circuit operates RXfrequency=TXfrequency cause coil is an air-core transformer... but you may have (and in tesoro's is always so) a different resonance frequency at RX LC circuit.
That cause full-resonance coupling is much more complicated to be realized in series, giving reliable results, by factory process.
about Useable frequency in VLF metaldetector ? (between ? KHz to ? KHz)
Hi Sisco,
sorry for the latency,
VLF frequencies ?
To be more technical in theory VLF is from 100 to 10Km wavelenght... that means about from 3KHz to 30Khz.
... in practice anything from e.g. 1-2KHz to e.g. 20 KHz or more... is suitable.
oh , please Max , for VLF metaldetector what frequency is
better ? (about sensivity , deep ,..)
Hi Sisco,
now I understand... you ask which frequency is better to gain sens and avoiding troubles...
First: it's not so critical factor for sens as on can think.
Well any frequency from 5KHz to 15KHz is fine for this, you have big response from foil without a good disc circuits if use higher frequencies e.g. near 20KHz.
At higher than 8-9Khz frequency you gain depth for smaller objects even thin ones, but have more ground and moisture influence. Need a good coil to run ok and a good design too.
At 5KHz operations are often so smooth, relaxing but most depends on circuit used.
I found e.g. Tesoro's really good running at 10KHz (bandidoII) and 14KHz (GSabre)... stable deisgns, cause are good designs! Of course you need also good coils for them.
I think that a detector running at 5KHz can avoid some problems in e.g. simple designs but low freq. is not required if design is good and disc is present.
Another thing to keep in mind is time response of detector that, if motion type, could be affected by a bad design and a low operative frequency.
Hello all.... well i have some questions for you guys... i have a original placstic sonde 25cm for DD coils, and im interested if someone can help me with number of coils for RX and TX for Golden Sabre.... i hope someone reply to my request.
