Originally posted by nelson
when you near some metal object to coil (not only DD type) and your magnetic field is unbalanced you get signal from detector, so it's normal having sound also on sides, but at very close distance and with enough umbalance due to target. But in DD the most senvitive portion is just under overlapping zone (in the middle). So you can e.g. on the field "pinpoint" targets , when have multiple sounds also on edges, just raising coil a bit to make side signals disappear, then using middle of coil to find exact "line" where target is.
On BandidoII there's another additional choice... one could push the auto-tune to "set" a minimum level of detection, then pinpoint with little movements (very good on concentric open centre coils).
Best regards,
Max
