Originally posted by ivconic
I plan to make a small modification to my own design for the all-metal mode, but this may not be until later today or tomorrow. Will let you know the result.
All that continuous beeping after making it "sing" with a coin ... Hmmm!
I would put money on it being caused by instability in the comparators. The only way you can get this continuous audio signal is if the wire-ored outputs of the two comparators are going high together. I did notice that there is no pull-up resistor at the output of the comparators, and these devices have an open collector output. Try putting a 1M resistor between the wire-ored outputs and the power supply rail. i.e. at pin1 U106a.
