coil noise
I am interested in noise people talk about, where it is from.
In my laboratory (spare bedroom, no workbench
), with my ridiculous unshielded coil and breadboard circuit, the coil creates the major part of noise. Not unexpected, it is a huge antenna for any kind of emf.
If I disconnect coil from circuit, noise drops down factor of ten (but still a lot).
So only way to observe typical working noise must be outside I assume. (But then scope not available. Maybe can run it from car battery.)
I am interested if anyone can do this: get outside with a scope and detector. Measure noise (I guess at output of LM308 ) with coil connected, then disconnected. Then measure noise shorting inputs to op amps one at a time up the chain, how does the noise change? What is the critical source of noise?
You would guess that LF353 pre-amp and LM358 front stage would be where noise is critical. Why is LM358 not an ultra low-noise component, like a biFet op amp?
Another source of noise would be subtle jitter in the JFet gate driver circuits. Very difficult to see because such big strong signal. But if LM393 triggers at slightly different points, it shifts driver square wave a little, causes "phase noise" so to speak. A little noise in the TX oscillator can change the zero crossings of the the LM393 that makes the gate driver signal, making "phase noise". But you hope that the same noise goes into the coil and back out the RX signal and gets balanced out. Who knows.
The wires from the descrim switch of course can pick up noise, but is after the LMM393, hopefully swamped and no effect. But that noise can maybe feed through the JFet gate to the JFet Source and get into the LM358 input.
So main experiments are:
1- noise with coil.
2 - noise with coil disconnected.
3 - noise with front LM358 input grounded before the 100K resistor.
4 - noise with front LM358 input grounded directly.
-SB
1- noise with coil.
-SB
