TESORO GOLDEN SABRE
    I dont want to bug you here, but really dont understand what is the problem with your handmades??? So many tries so far???
    Could be coil, but also could be anything else. In most of the cases chatters DO appears if coil is not made well. In most ... - not in all cases.
    Inside the house or outdoor - you MUST NOT have chatters at all. When sense adjusted to maximum - the same, you must not have chatters. Chatters...but very rare and mum can appear ONLY on some not so oftenly met areas on soil, where certain mineralisation is presented in higher percentage, even than only if Sense is on maximum.
    Also i do not understand all those "philosophy" you elaborated here so far???
    Can't you simply obey given datas? You have 100% accurate schematic posted many times here on this thread. Also you have few very good pcb's, tested and aproved in many (32 cases so far at me) cases. Coil....coil is not piece of cake to make...yet, again, it is not so hard to make also. Simply use proper wire and on given former achieve 6 and 6.5mH and that is all. Apply Al shield, leave 1cm gap, connect those as on given sketch and balance it with patience.
    Ok...for now DO forget nulling with scope or millivoltmeter. Just forget that. Null it just with coin. Swing coin over it and null it, again and again. Try to achieve best distance in air. You simply must gain 30cm on 1e coin cose it is the least you will have to achieve. Inches above 30cm are success, usually gained if everything else already done perfect. But 30 cm on 1e coin in air is starting point - least that you will have to achieve.
    Do NOT change neither one component value from given schematic.
    Reading some post here i saw that you already experimented with some components values and changed wildly!?!? Why? Who told you to do that?
    No wonder why you confused yourself more and more.
    Now is a hell of task to return it to good setup and to balance coil to work good.
    Usually that's the case when experimentator "overexperiment" to much. Dont ask me how i know that!
    Hopefully you will not understand this as bad attitude but as positive and productive criticism in hope to help you to solve the problem.
    Regards!
    I appreciate good advice, no problem anytime. Even criticism, what the heck.
    I broke my rule and posted some ideas I should keep in separate thread so not confusing to anyone who is following the "tried and true" instructions.
    I'm not worried about my own detector as I'm having fun experimenting. I can always return to "exact spec", no problem.
    My goal is to learn how to "tune" best, even if deviate from exact spec. For example, I made some coils with very low resistance (7 ohms). Causes problems for sure, but I think there is a way to compensate. But I'll keep results in separate thread because it is confusing, I agree.
    I also want to use TGSL as basis for alternate designs. For example, slower reponse version; 180 deg disc version; "simple" notch version; dual response version; super-tune resonant version; etc. Just some ideas that pop in mind -- but I have to keep reminding myself -- SEPARATE THREAD!
    Another goal I have is trying to try easy construction methods when don't have good tools or shop. Sometimes funny, usually don't work, but maybe useful to somebody someday -- separate thread!.
    But anyway, I'm interested if Ultimate Haze can make handmade TGSL go deeper and how done.
    -SB
    • Originally posted by Ultimate_Haze View Post
      OK,
      Max.
      Tks.
      I will do as you say.So you advice me to try with less turns,so I can reach higher freq.?Haven't noticed but its rely too low indeed.
      Made a funny test today.Changed BF245C with PN4393.The frequency now with same coils is around 24,4kHz.Better iron disc and a little sense.Now 24-26cm.But its too wrong 24,4!Gonna solder BF245C back.
      Problem is coil for shore.I try to reach 6,00 and 6,5mH inductance and forget to look at tx freq.
      But with last former posted here in pdf I made 110 TX windings to reach 6,0mH and around 112-114 for TX 6,5.And they should be TX 100/ RX 105 right?With this setup not good results so far.And I get wrong inductance.
      Where are you using BF245C and PN4393? Are you sure you measure freq correctly?
      -SB
      • Simonbaker,
        3. TX frequency -- if too far from RX resonant frequency, you lose gain. You can either raise the TX frequency (by lowering inductance of TX coil, or decreasing capacitor C2 .022 uF) or you can also lower the RX resonant frequency by increasing capacitor C6 (.015 uF) or increasing inductance of RX coil. This increases gain, but watch out, if you go too far you alter phase of target signals and discrimination won't work well.
        That definitely works +3 сm for my TGSL with adjusting of TX frequency with the C2 capacitor. About 28 cm for 1 euro coin after this adjustment. Thanks!
        I think that the original sound with MPSA 14 transistor is a little noisy in home conditions.
        • Originally posted by Aiko View Post
          Simonbaker,
          It may have nothing to do with my reasoning, but glad you have more depth! I know you tried increasing C6 which should be similar but you found not stable, so for some reason this worked. Sometimes just resolder improves!
          What frequency change did you make (from-to)?
          -SB
            -SB
            Yes i support and understand your attitude. Besides...i experimented much also. Thinking......again must be the coil, cose really original TX/RX at TGS does not need some modifications, it works very clean and good. Like i posted so many times in the past; i dont like only audio part at it.
            TGS/TGSL needs mostly better audio. I gained better audio...much better, with last BD140 mod. Yet...it is half way to become good. Not satisfied yet.
            I would be more happy to see various ideas on that subject here.
            TGS/TGSL the way it is projected now is splendid coinshooter. Maybe needs more power to go deeper on larger items and for sure needs much better audio. I am to much occupied latelly to continue my works on it. Also Eldorado now looks more promising to me. If i ever continue to deal with that i will rather take Eldorado as starting platform for experimenting.
            Cheers!
            • TGSL Disc
              Dear All
              why doesnt TGSL reject gun bullet?
              kind regrads
              • Originally posted by metaldetector107 View Post
                Dear All
                kind regrads
                Ha,ha,ha! Are you joking!?
                Gun bullets are usually made from lead (with or without brass or steel sleeve). Why should anybody want to reject lead? It is coloured metal with very nice features. Show me one metal detector on market with feature to reject lead!? Except some poor PI...
                  Dear All
                  kind regrads
                  which kind ?
                  Lead made , old style ? Already answered by Ivconic....
                  Some are made of different stuff...
                  also depleted uranium!
                  Beware of those... are HOT stuff...
                  I know people (childrens mostly) in your country found them in the streets after A10 raids... and tank perforating ammunitions used... and PLAY WITH THEM...NO GOOD.
                  People beware of those!
                  Same apply to Serbia and other countries.... that share same "luck" after NATO raids!
                  Now about all balcans are scattered by these things in soil... NO GOOD.
                  Ivconic surely knows... as well other people, thunters there.
                  IT'S REAL, REAL AND HEAVY DANGER.
                  But maybe you mean AK47 stuff... ammunitions and some western made too... some are lead with copper jacket + nickel etc... full-metal-jacket things uses also some kind of steel.
                  The fact MDs detect bullets is usually a PLUS... of course, as with any thing, depends on scenario... if have all search field full of them it's really annoying stuff... and also potentially dangerous if some are radioactive too!
                  Kind regards,
                  Max
                    Simonbaker,
                    Can you make some conclusions?
                    No matter what I try so far this last TGSL just refuse to work like it should.
                    Now after so many coils I am shore that coil is problem that can't solve so far.
                    I use 0,25 bare wire.0,27 with varnish.
                    Old DD27 that were made for previous TGSL device.:
                    C12 .096
                    C15 .161
                    TX 6,21mH 27,9
                    RX 6,77mH 29,1
                    13kHz
                    nulled to .050
                    OO coil
                    C12 -.073
                    C15 -.325 Why both -
                    13,7kHz
                    TX 6.00 26,6
                    RX 6,58 27,6
                    nulled to .200
                    Both coils shielded.And sealed with epoxy.But I still have this poor performance.Low sens.1 euro coin at 22-23cm.
                    RX cap is 15N.Now I put 100k pot for.GEB.
                    My last /still not shielded and sealed coil/isD27
                    TX 5,93mH 26,7
                    RX 6,58mH 28,0
                    13,9 kHz
                    C12 .209
                    C15 -1.185
                    I now that I miss something and just looking for solution.Because I like this project.
                    (I moved answer to different thread because too confusing here for people building standard TGSL.)
                    http://www.geotech1.com/forums/showp...0&postcount=26
                    -SB
                      Cheers!
                      I hope someday you can look at Vaquero -- that is purest machine I think. But too new I guess. Standard coil is concentric with very small center coil, but it gets good depth -- how??! Electronics must be very good.
                      We'll look forward to your work with Eldorado!
                      -SB
                      • I had chance to see Vaquero. Nice machine. Tejon looks even better. Reffering Vaquero; i measured coil....right now i dont have notebook with those datas, yet i remember datas were pretty close to Minelab coils!!??? Something arround 1mH and 16mH!?? So...what i done? I connected 39cm Minelab Relic Hawk DD coil to Vaquero and guess what? It was worked excellent and very deep!
                        I also spotted some long chip inside. Didnt have time to examine it closer. Also there was some sticky label on it, covering its original label. I guess it would be hard to copy it, cose of that chip..Not sure what it is?
                        I had Vaquero just for half hour to test and examine..so i didnt have enough time...
                          Tejon sounds like excellent super sensitive machine, good basic controls. Just reading other peoples' experience maybe best for soil with low minerals, but who knows. It would be interesting to compare circuitry on Vaquero, Tejon, Lobo. Some day in future...
                          -SB
                          • "...low minerals.."
                            Yes, you got that right! Tejon is extra deep detector.....but it chatters much for my taste! I had chance to test it outdoor. It is very deep. And it chatters constantly!
                            A bit solace is in fact that ..for example; coin signal differs significantly from ordinary chatter so operater can easilly distinguish good signal among all those chatters.
                            Same behavior i experienced with XP detectors; more with one on 4.6kHz and a bit less with one on 18kHz....
                            All this noticed when mentioned machines are adjusted to run pretty hot. Otherwise those are not deep at all - those are average.
                            So... our TGSL is not bad at all....after all! Even when it is adjusted to run very hot - it remains pretty calm and cool!
                            That's why i LOVE TGSL and also respect much Minelab Musketeer Colt. Colt is extra cool even when adjusted to run 100% hot! I like it! Small beast!
                            • Hi to all
                              What is the diference between LF353N and LF353P.
                              • Originally posted by Darko View Post
                                In practice ?
                                None.
                                The N version is low-cost plastic dual in line; the P version is plastic dual in line.
                                In practice, some brand use N for "normal",meaning low-cost mass produced parts and occasionally also P for other production lot of same range.
                                Different manifacturers uses different suffix for same range of devices.
                                You can then safely assume there will be no relevant difference between an LF353N and an LF353P.
                                Things are different, instead, if you get LF353AN: in that last case the A means the part is better than average/common parts.
                                This is an old convention due maybe to Texas Instruments labeling system.
                                Kind regards,
                                Max
