Hi
I used 12v 45Ah car battery for test.
also used 1100miccrohenry D=5cm small coil,ırf840 ,vu meter, and 0.5W 8ohm speaker.
rest are same with kt315 's list.
first I hear sound like door creak .(tik tik ) it continues something like 10 seconds .then stops .and when I put metal (it was iron) infront of coil ,I got no sound.
when I repeat process.I mean close and open detector .same thing happens again.
I controlled coil .it is ok mechanically. but not sure for tx signal .
where is the problem
I connected 555's 2. & 6. pins.
And on vu meter there is + and - inputs.where must I connect them.which one is jp1 (+ or -)
