Hi Everybody,
I am planing to have discrimination with PI s.
to do this I need some scop results.
I want to see the end (die) times in microseconds and movement of grafic at
these conditions ;
we will use two meterial types.gold and iron.
coil can be small coil.and must be constant during all tests.
1) change of grafic while changing distance of gold(ring or bracelet) to coil.
measurement distances are 10cm,20cm,30cm,40cm,50cm
2) same for iron meterial.but size must be close to gold sample.
3) this time distance is constant.you can chose suitable distance (10,20,30,40) according to tests.
we will change size of target. both for iron and gold.
ı know it is difficult to find gold .but use anything you have with different sizes.
and also double reflection area of iron at each readings.like surface area=A
first A ,seceond 4A ,than 8A,16A . we must start A from coin size.
with an other aspect increase diameter .for example
D=2cm
D=4cm
D=8cm
D=16cm
D=24cm
D=32cm
4) last one .for this test important result is end times.(microseconds) of different targets.
targets are all gold.but different values gold. I do not know how to say it in english. kirat ,degree, like 16k (for rings) ,18k ,22k (for bracelets)
these conditions ;
D=2cm
D=4cm
D=8cm
D=16cm
D=24cm
D=32cm
