I remember Wirechief asking once about the signal from a PI into the ground and how much the ground dampens the signal and how far the signal reaches, at least this is what I believe was being discussed some time ago on several forums.
Hat if we were to make small coils of different # of wire wraps, extend the leads to a meter and bury these coils at different depths in a controlled volume of earth. The coil might be as small as a dia of a pencil or other sizes
the purpose is to find out the true signal strenth of a PI MD by the induced voltage from each of the coils. The advantage I see is that this might give a standard to work from instead of a nugget response that has to create the eddy current then the response back to the coil.
Eric was looking into the magnetic suceptability of different soils.This would show the absorption(possibly) of these soils.
Maybe this is already being done by ML or Eric or others and I am not aware of this. But this might help homebrew "See" the output signal better.
Any thoughts, Wyndham
