[[[[[ Varistor ]]]]] or VDR
  • [[[[[ Varistor ]]]]] or VDR
    Hi all,
    I saw a VDR in a circuit some time ago, but I don't know what they do....?
    Could someone explain about them?
    What advantages they have?
    Is it possible to use two zener diodes (by fasten both kathodes of them together) insead of a VDR???
    Best Regards,
    1843
    Voltage Detector Reset. Basically, it monitors a voltage and if it falls below a threshold the detector triggers an output. In other words, it's a comparator. No, the zeners would not do the same thing.
      Hi Carl,
      I have seen VDR also stand for Voltage Dependent Resistor which is basically a varistor.
      Here is a link to some info about them.
      http://www.epcos.com/inf/70/db/var_01/00190041.pdf
      Reg
        Hmmm... OK, also a Video Digital Recorder.
        So a VDR looks a lot like a back-to-back zener, but instead of a sharp avalanche it has a more resistive slope.
          Many thanks to Carl and Reg,
          Cheers
