MINIDIVER (minipuls+minediver)
  • #31
    Geo , can tell me find these clocking by calculate or osciloscope?
    my tiny clocking is calculated (not see in OSC).
    see this picture , if 4538 datasheet is true my calculated must true.
    1set Delay =>R1 X C1 => (SIGNAL pot + R7) x C1 =225us - 975us
    1 sample width =>R2 X C2 => 40us
    interdelay =>R3 X C3 => (SENS pot + R9) x C3 = 1ms - 8.5ms
    I test my minipuls with digital OSC and saw , yes Max your answer is true :
    minipulse 1set delay was 7us (infact 6.9us).
    • #32
      Max , interdelay must 200us distance with ending of 1sample delay ,true ?
      • #33
        Hi Sisco .
        I measured the times with Oscilloscope.
        I have one original DP and other 2 made by me. All have the same clocking.
        But if i remember OK potentiometer SENS is 220K at my Detector.
        • #34
          Hi Geo , I true understand ?
          • #35
            Hi Sisco .
            220k not problem, bicause in minimun time (only R9) interdelay must 1ms not
            120us??
            are you sure don't change R9 , C6 , R7 , C4 ?
            because in delay width my calculated like you (40us ~ 45us) ?
            • #36
              Hi Sisco .
              Of course i am sure. I have not changed anything.
              But at your schematic out1 must be 15us after the "IN pulse" fall
              I attach the clocking of my DP
              • #37
                Ok Geo ,
                I write this program , start first delay after "IN pulse" fall.
                see and tell me this is true?
                • #38
                  I have a better idea , why must use NE555 for make pulse , can use micro
                  for do this .
                  Max, see this schematic and if this is true tell me , I have make it and test
                  your idea about timing.
                  If don't work.....
                  • #39
                    for do this .
                    If don't work.....
                    It seems OK
                    Good Luck
                    • #40
                      for do this .
                      If don't work.....
                      you have to put a differential integrator between sampler and audio stage.
                      Look at hammerhead pdf for more details about that.
                      Kind regards,
                      Max
                      • #41
                        Hi Sisco and congratulatins for this beautifull MD you have done.
                        I m still working with my Tesoro Golden Sabre, but after that i ll try a few more projects and this one looks very promising, so i started to collect information about construction.
                        So, for that can you send me the PCB file?
                        In advance many thanks
                        Nelson
                        Hi all ,
                        Finally, ready my new project ,
                        first , I can't find tel-12... part so use two battery but if you can find this
                        part not need two battery.
                        second, you can see original minediver in this address:
                        http://www.pulsdetektor.de/projekte/projektindex.html
                        I am busy and very tired, so test this metal detector for 4-5 time but
                        understand :
                        abut sensibility , with very good adjust with 35cm coil can detect
                        50cm X 50cm at 2m. (I only can do this for two time because can't adjust
                        very good in home).
                        with 35cm coil detect small silver ring at 19cm
                        and for other test like small coil , gold (because this metal detector have
                        DELAY adjustment) must wait, because my battery under charge.
                        If somebody have PCB layout tell , I send .
                        be successful
                        • #42
                          Hi nelson
                          first must tell , this metal detector very good for deep and finding small
                          object but have a problem , not sensitive to gold.
                          I try to find way (with change delays) for this problem.
                          this is PCB layout for minidiver.
                          • #43
                            Max , your idea about timing , I want first make new device for test your
                            idea but think and decide first test this timing on my minipuls.
                            so erase minipuls ATMEGA8 and programmed by new program (1KHz ,100us
                            PW ,15us , 45us first delay , 200us interdelay and 45us second delay) and
                            test , what you think ?
                            YES this work and I can detect GOLD with this timing.
                            this is my programm writed on ATMEAG8.
                            evrey step =3.75us for example A = 27 mean this time is 101.25 us (IN THIS TIME MOS-FET IS ON)
                            $regfile = "m8def.dat"
                            $crystal = 8000000
                            Config Timer1 = Timer , Prescale = 1
                            Stop Timer1
                            Config Portb = Output
                            Config Portd = Output
                            Portb.1 = 0
                            Portd.6 = 0
                            Portd.7 = 0
                            Dim A As Word
                            Startline1:
                            Start Timer1
                            A = 0
                            Portb.1 = 1
                            Do
                            A = A + 1
                            Loop Until A = 27
                            Portb.1 = 0
                            A = 0
                            Do
                            A = A + 1
                            Loop Until A = 4
                            A = 0
                            Portd.6 = 1
                            Do
                            A = A + 1
                            Loop Until A = 12
                            A = 0
                            Portd.6 = 0
                            Do
                            A = A + 1
                            Loop Until A = 53
                            A = 0
                            Portd.7 = 1
                            Do
                            A = A + 1
                            Loop Until A = 12
                            A = 0
                            Portd.7 = 0
                            Do
                            A = A + 1
                            Loop Until A = 158
                            Stop Timer1
                            Goto Startline1
                            TIMING:
                            Frequncy = 1001.5 Hz
                            PW(ON PULSE) = 101.25us
                            delay= 15us
                            first delay = 45us
                            interdelay = 198.75us
                            second delay = 45us
                            OFF PULSE = 592.5us
                            FOR 1000HZ:ON Pulse is 100us so OFF pulse must 900us calculate = (15us+45us+198.75us+45us)-900us =~595us
                            • #44
                              $crystal = 8000000
                              Stop Timer1
                              Portb.1 = 0
                              Portd.6 = 0
                              Portd.7 = 0
                              Dim A As Word
                              Startline1:
                              Start Timer1
                              A = 0
                              Portb.1 = 1
                              Do
                              A = A + 1
                              Loop Until A = 27
                              Portb.1 = 0
                              A = 0
                              Do
                              A = A + 1
                              Loop Until A = 4
                              A = 0
                              Portd.6 = 1
                              Do
                              A = A + 1
                              Loop Until A = 12
                              A = 0
                              Portd.6 = 0
                              Do
                              A = A + 1
                              Loop Until A = 53
                              A = 0
                              Portd.7 = 1
                              Do
                              A = A + 1
                              Loop Until A = 12
                              A = 0
                              Portd.7 = 0
                              Do
                              A = A + 1
                              Loop Until A = 158
                              Stop Timer1
                              Goto Startline1
                              TIMING:
                              delay= 15us
                              first delay = 45us
                              second delay = 45us
                              OFF PULSE = 592.5us
                              Well done.
                              Now test if it gives false signals or not if you can.
                              Kind regards,
                              Max
                              • #45
                                HOW?
